Cell Phones Logo
Mohit Shrivastava Posted on Oct 29, 2009
What is the default password for micromax x211 mobile. When we go in menu -> securities -> Phone Lock. It ask for the password. That is a default password. Because i have not set the password yet in this mobile.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 01, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3393
Points
19
The default password of micromax
x211 is-----1122
Anonymous
Level 1:
New Friend:
  • Posted on Dec 26, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3393
Points
19
Which video format support by Micromax x211
Anonymous
Level 1:
New Friend:
  • Posted on Aug 05, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
3393
Points
6
X211 insert sim solution
Anonymous
Level 1:
New Friend:
  • Posted on Apr 06, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3393
Points
Camera module not ready
Micromax master resetting code all
1.NormalReset - Dial *#7780#
If you dial this code in Nokia handset, it will restore system setting without missing phone memory data (videos, photos, songs).
2. .Deep Reset - Dial *#7370#
When this code isdialed in Nokia handset, it will wholly clean internal phone memory. Entire phone settings and profiles will be deleted, but there is no effect on memory card data.
Remarks -
For Nokia Symbian 60 V1 supported mobile handset (7650, 3650, 3600, 3620, 3660, N-Gage)
you can dial *#7780#*#7370#
Latest S60 mobile handsets, you can dial Deep Reset through another way.
*.Switch off mobile handset first.
*.Press calling key (green), 3 and * keys or (Green calling button + 3 + *)at same time and grip them down.
*.You find a message about format mobile and then release these keys.
*. Password of Reset factory setting code will be either 1234 or 12345.
Nokia X3-02 mobile Restorefactory -
*.Go to Nokia menu lists, browse these options one by one-
*.Menu --settings-- Menu--- Restore Factory Setting
*.Insert phone code 12345and wait few moments to complete restore process.
Nokia 5230, 5800, 5233 and similar mobile handset Restore factory settings, how ?
*.Browse phone menu lists,
*.Then, go to
Menu - Settings - Phone -- Phone mgmt Factory settings
*.Insert security code -12345
*.Without data lost of internal memory, Nokia handset returns in original modes.
Hard reset of Latest Nokiahandset through another code -
*.Switch off mobile handset.
*.press and holdGreen (calling) +Red (End call button) + Camerakeys at the same time along with switch on power of mobile handset.
*.Then mobile asks to insert phone security lock code , so insert12345.
Samsung Restore factory code
*.*2767*3855#
*.*7465625*638*00000000*00000000#
*.#7465625*638*00000000#
or
*.Remove SIM card from mobile handset
*.Once off and on handset
*.Type *2767*2878# to perform internal memory reset
*.Insert SIM card again in mobile.
Samsung Androidsupport handset restore factory code -
Type*#*#7780#*#* - To Factory Restore.
Micromax Restore factory code for all version with Android -
You can use any following below code one by one to perform restore factory of Micromax mobile:
*.1122
*.0000
*.1234
=*symphony> 1122
=*nokia >5071 or 0000
=*micromax> 1234
=*tecno > 1234 or 0000
=*samsung> 1234
=*apale i phone >5869
BACK2HOME
Information from:
http://peperonity.com/sites/a--a.secret.mobile.codes/47096442
Terry
How to reset security phone password of samsung gt s5230????
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Where shud i put the code?? how to use it??
sir the phonelock of your cellphone has work like.if you switchoff your cellphone and then switchon the phone will ask the unlock code.if you like to put the code go to the menu > settings > security > lock > phone protection > select and enter the default code 0000 and then enter the new code repeat the code to conform on and the phone protection lock will be on. don`t forget the phone password number............
3helpful
2answers
Restore factory password for macromax x211
mare micromax mobile se koe pan karnosar setting change thay gaya se mare incoming call avta nathi out going call *** che to restore factory setting password apva namr vinti
23helpful
8answers
NEED DEFAULT RESET CODE
type *#06# on your phone to get it.
1helpful
I have purchased a samsung duos 259 phone...
hi, you can lock your messages like menu--> settings--> security-->phone security--> privacy lock-->message lock.
phone lock is by default long press" * " so you can't change it by using any software and via samsung center also...
M.P.Kumar
24helpful
2answers
Whats the default security code for Micromax X250 mobile
i forgot the password for my new micromax 250 cell phone..i am afraid tat my sim might get rejected cos of wrong input of password...can u help me...
Oct 20, 2009 • Cell Phones
2answers
Iam not able to unlock it
if you change the default security code of your phone, you have to bring it on any authorized cellphone repair center to retrieve again the password.
hope this initial info helps.
16helpful
3answers
WHAT IS THE VIDEO CONVERTER OF MICROMAX X211
this is use avi low Quality format Try smart movie converter the display option set u r display size Eg. 240*320 then convert & use
Apr 23, 2009 • Cell Phones
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
