My 16 gb gogear froze
My 16 gb gogear aria froze one day and then i pressed the reset button and only goes on the welcome screen and automatically turns off. reset button doesn't work even plugging it in my computer doesn't work.
Posted by checkdafool3 on
Anonymous
    New Friend:
  • 13 Answers
1 On your computer, select Start >
Programs > Philips Digital Audio Player
> Aria Device Manager > Philips Device
Manager to launch the Philips Device
Manager.
2 Turn off GoGear Aria before you
continue.
3 Press and hold the volume button
while you connect GoGear Aria to your
computer.
4 Keep holding the key until the Philips
Device Manager acknowledges GoGear
Aria and enters the recovery mode.
5 On the computer, click the Repair
button and follow the instructions of the
Philips Device Manager to complete the
recovery process.
6 When the recovery is completed,
disconnect GoGear Aria from your
computer.
7 Restart GoGear Aria.
The full manual is found here: http://www.p4c.philips.com/files/s/sa1ara16k_17/sa1ara16k_17_dfu_aen.pdf
Posted on Oct 29, 2009
White screen
Try resetting your tablet. Google search your make, model and reset. Follow the instructions from one of the results provided.
1helpful
The screen is frozen on the PHILIPS icon and when i reset it it did nothing, but when i put it on the charger then reset it, it starts charging, but when i take it off the charger it goes back to the...
Please follow the below steps and check if that resolves the issue:
  1. Press down on and hold the "Power" button on your Philips GoGear MP3 player.
  2. Press down on and hold the "Volume Up" button on your Philips GoGear MP3 player. Continue to hold both of these buttons down for three consecutive seconds. The MP3 player will turn itself off.
  3. Press and hold "Power" until your Philips GoGear MP3 player turns itself back on. Your GoGear will no longer be frozen and you can use it as normal.
If you require further assistance then please revert back.
Regards
Anand Gupta
5helpful
3answers
I tried the reset button but it cant reset. it turns off at the welcome screen
Hi, there are two types of reset mode:
The soft rest,
And the hard reset.
soft reset by pressing the power button and volume up (+) button together. if It didn't work. you can do the hard reset.
hard reset by pressing the reset button (its a small hole next to usb connection socket) with a safety pin. It worked. Thankfully it does not delete any of the content on the device .
Have a nice day...
10helpful
1helpful
My screen on the MP3 player froze and won't let me do anything like change the song or anything. Can you please help me fix this so i can use it again? Also is there a reset button on it.
  1. Press and hold the Power On/Off key and the Volume + key for a couple of seconds until it goes off.
  2. Then switch it back on using the GoGear using the Power On/Off key.
2helpful
2answers
3answers
Stuck on welcome page
I have the same exact problem, i bought 2 of them and both have the same problem.
1helpful
Philips GoGear 30 GB HDD6330 Won't Turn on.
Try a soft reset by pressing and holding [VOL+] & [POWER]
whenever this happens, then try powering up again.
If this doesn't work, it could be corrupt firmware. Run the Philips Device Manager software (on the product CD). Select the Restore / Repair option and follow the on-screen prompts.
This will format the player and re-flash the firmware.
Note: ALL tracks will be deleted from the player.
Open Questions:
0answers
My Cyber Acoustics set of stereo speakers plugged into my MAC MINI suddenly is not found in my system preferences on my MAC MINI Model # CA-2022R (I think). My Cyber Acoustics set of stereo speakers plugged into my MAC MINI suddenly is not found in my system preferences. I just recently updated my MAC's software to MAC's new Monterey 12.0.1. Apparently or at least seemingly, my speakers, although on, won't put out any sound now. My computer is no longer acknowledging their hooked up presence. Through hit and miss, I was at least able to turn on my MAC's own built in speaker. It sounds awful compared to the high quality sound of these speakers. Apple support has no idea WHY my computer has stopped acknowledging the presence and still plugged in and switched on. The blue power light is on. CYBER ACOUSTICS set of 2 stereo speakers. Is there hardware / software that I can download back into my computer that will reactivate my 2 speakers? I DON'T KNOW THEIR MODEL NUMBER FOR SURE but I think I saw CA-2022R. I have already tried unplugging them and then plugging them back in repeatedly but that doesn't help. I even re-updated my computers software for the second time with the same new Monterey operating system 12.0.1. I have no idea what else to do and Apple support is clueless. My MAC simply no longer knows that I have a set of Cyber Acoustics plugged into it. PLEASE HELP ME GET THIS TO FUNCTION AGAIN. I even momentarily plugged your speaker's green plug in into the head phone jack on my iPhone and it worked perfectly and sounded great as usual. Then I plugged it back into the back speaker input on my MAC MINI.
Ekse
 Grubhead
Grubhead
