Syntax-Brillian Olevia 242TFHD 42 in. LCD TV Logo
Posted on Oct 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Olevia 242 S11....suddenly went black while waching top cheff....its on but there is no rersponse at all...beyond turning on and off....
Anonymous
Level 3:
President:
  • Syntax Master 1,779 Answers
  • Posted on Oct 29, 2009
Anonymous
Syntax Master
Level 3:
President:
Answers
1779
Questions
Helped
580432
Points
5452
Most likely, bad capacitors in the power supply.
1helpful
Olevia 242-S11. Have to turn tv off and on 6 times before sound stays on. No problem with picture.
Menu , sound settings, disable all special effects , Dolby surround, stereo, etc.. unplug, Wait overnight plug back in see if the problem continues if so, check sound settings they should be the way you left them
My olevia 242-s11 want turn on changed power supply and main board whats next
Two things, assuming you installed a working power supply and main board, check to make sure the kill switch is in the "On" position. If my memory serves me correctly, this set does have one. Are you sure you have a working outlet? power cord? When you say the set won't turn on , are you referring to the entire set or just the screen?
I have vertical lines on the entire right side of the screen on my Olevia 242-S11. I've replaced the t-conn board three times, the first and third gave me a black screen, the second gave me less...
most of the stuff from jimmy's its second hand ( not good working or working maybe) first and the last i suppose you got a problem with the power supply on the T con on the second i suppose you have a problem with the big chip in the middle the scalier :D
Olevia 242-T11
Screen went black unpluged won't even turn on.
Olevia - hidden mini HD service input
I have pictures of the USB port, as well as the procedure of what I did, once the USB trick quit working here: http://www.flickr.com/photos/geegee123/sets/72157607269121264/
What is code for Olevia 42" TV, Product # 242-S11?
I have the Olevia 65 inch LCD TV and cannot find the comcast remote code for my TV! Any help?
Top Syntax Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Syntax Televison and Video Expert? Answer questions, earn points and help others
