Honda Accord 1998-09
To reset MAINT REQ’D light, press and hold select/reset button on right side of instrument panel. Turn ignition on and hold until the light goes out.
On the right of your dash is a pair of buttons, one for selecting/changing the odometer and the other for cycling from MPH to KMH and back.
Turn the key on.
Push the select button until your display indicated the remaining oil life percentage. When it is displayed press and HOLD the select button until it begins to flash. Once it starts flashing release the button and press and hold it again. The display will clear and if you release the button and cycle through the display with the select button you will see oil life 100%. Good luck and this should reset the oil life.
SOURCE: reset oil light
if its the lil red oil light on the dash., you cannot reset it. it means lil or no oil in the vehicle
SOURCE: Wondering how to reset maintenance light on a 2005 Honda Accord
Look in the owner's manual. It has it in there how to reset it. Usually it just has to do with selecting the oil quantity select and holding it down....or cycling the ignition a few times. Check your manual though....it will have it in there.
SOURCE: 2008 honda accord replace rear brakes
no, 12mm wrench or ratchet on 12mm socket. the piston is tough to push back in. its a twist in type and you will need some force to push and twist the piston back in. - note rear brake pads wearing out on the new 08-09 accords are very common and if under 16-18 thousand miles it may be covered. honda knows about this problem
SOURCE: We have 2008 Honda accord. There is yellowish
It means it's time for service---- to change engine oil -- check air filter and various maintence stuff--- if you have the owners manual it will show you what service to perfoam and to log it in the service book.
Also has intructions in the owners manual as to how to reset the service warning light-- kind of tricky but once you get it it's pretty simple.
SOURCE: 1997 honda accord is leading oil
mainly oil leaks are caused by a bad gasket....you can try to replace it if you want, but its recommended that you take it to a car shop...if the leak is bad enough
