That bar your talking about goes to the full up position just before the end of the harvest cycle then falls right at the end of the cycle. But on a good day it barely drops. Characteristic of that ice maker.
If you ran water over the ice maker try these 2 things.
1. Remove the ice maker and leave it on the counter for about 2 days to completely dry out. Then re-install and try again.
2. If no luck, hang a small weight to the middle of the wire to see if it will drop on it's own.
3. If no luck, you'll have to replace the ice maker. However,
if your commited to buying a new ice maker, first snap off the front cover and look for interference where the wire goes into the ice maker. You can actually remove the whole solid state front end by removing the 3 screws that hold it on and make a more detailed check.
P.S. pull the wire out of the ice maker before this last step. It simply pulls out.
