Electronics - Others Logo
Posted on Oct 28, 2009
I cant format a removable disc - Electronics - Others
Anonymous
Level 1:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Oct 29, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
12
Questions
0
Helped
5272
Points
22
I have used this sd card format utility to format removable drives with success, here is the link:-
http://www.sdcard.org/consumers/formatter/#download
You need your PC to recognise the removable disk when inserted to be able to use this utility.
2answers
I am not able to remove disc protection
format it useing nokia 6120c,6220,and c5-00 phone.. or view this site= http://www.makeuseof.com/tag/format-write-protected-usb-flash-drive/
I cant play pal formatted discs on my dvd player
PAL is the European format and will only work in PAL DVD players. You need to either get a NTSC (US) formated disc or a PAL formatted DVD player.
Cant get pre-recorded disc's to play in my recorder it comes up with the message "this disc will neither play or record" any ideas?
hello,
the reason the recorder comes up with the message "this disc wont play or record" simply is that the format of the disc is not compatible with the player.
1. check the format of the recorded disc,
2. and check the formats the recorder can play to confirm this.
take care
7helpful
3answers
How do I format a disc (DVD or CD) on Windows XP?
You only format a CD/RW or a DVD/RW, which are re-writeable.
Regular discs do not need to be formatted (CD-R or DVD+R, DVD-R, DVD+R DL, etc.).
To format the DVD/RW idisc, use the "burner" software ( Sonic?, Nero?) and choose [Tools] [Erase Disc] (erase is the same as format)
8helpful
Cant play dvd cd or even eject the disc that is already in .
actually it is due to faulty disk or dirty lens sometimes , when the lens is dirty it keeps on trying to read the data from cd or dvd and it just cant stop that infact stuck in it , or the other reason is faulty loading gear , in either case u have to physically dis assemble the player , remove the top cover some 4 or 6 screws are there in place open the top cover see the cd /or dvd and remove it physically do not force anything hard when removing the media and then if u can see the lens of ur player just clean it with a soft cloth with ur fingers in cicular motions very gently and u will see that it will play dvd /cd fine , the other thing if the loading gear is faulty or broken then u can ask me more on this
Pls rate me WELL !
5helpful
Verbatim 4gb flash cant be recognised
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
2answers
Recorded DVD will not play in another player
Hey,
Maybe the format of your recorded movie didnt support your player..check out your manual for the supported formats and check the format of your recorded movie.If any of the format in the manual matches your movie format then it will definitely play..
please rate my suggestion..
29helpful
3answers
Cant finalize dvd on a magnavox zc320mw8
you have to push stop from the title menu, then push setup. Then go to disc edit and finalize is there
Not reading disc
Hi i have had a few cd's/DVD's repaired by blockbuster, they charge about 2 to 3 GBP and so far i have had no problems.
this works by removing a layer of plastic from the disc.
if this fails then it my be worth getting your unit serviced as the fans puill in a lot of dust from inside the car..
Mark
www.carradiospares.co.uk
www.blueice-electronics.co.uk
2answers
Can finalized but the last clip in the dvd cant be retrevied
the message is the file is corrupted and keep asking user to format the DVD (using camcorder)
when usng Elead it just said the file is corrupted and the windows it self also show that the DVD is empty/blank.
i'm using DVD-RW and VR is the recording format.
Top Electronics - Others Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you an Electronics - Other Expert? Answer questions, earn points and help others
