Question about Kohler Home
My whirlpool tub is not working. Nothing happens when you push the button. Is there a reset button for the jets? What should I look for?
  • Anonymous Mar 27, 2014
    Push button does not turn jets on. Tried prying up the button but unable due to possibly breaking plastic parts
Anonymous
    Problem Solver:
  • 10 Answers
First check the air switch hose that connects to the "button"
Open the access for the pump there should be 1/4" poly tubing (probably clear) that connects to the pump motor. It just slides over a barbed nipple usually located somewhere on the back of the pump housing opposite the pipe connections. Make sure it is in place properly. If it is in place then look else where. The tubing also connects to the back of the air switch "button". This button connection rarely fails, especially if the tub was working and now does not. But if the tub is newly installed and may have disconnected during installation. this connection is probably going to be difficult if not impossible to verify since it is usually concealed after installation.
Some pump motors have resets some do not. If it does it probably is on the very back of pump opposite the pipe connections.
Also check to make sure that any electrical outlets in the bathroom, or any where in a nearby radius of the tub, to see if they have "GFI" reset buttons and make sure that they havn't tripped by pushing in the button between the plug-ins named "reset". Usually the circuit for the pump will be tied into one of these switches to add ground fault protection to the circuit.
If your pump is not working after checking these things it may be dead. Does your pump "hum" after pushing the button? Do you smell any type oder around the pump that would suggest a "burnt motor"?
If the pump is dead you will have to replace it.
Come back here and post more if your problem isn't solved. Or ask how to find and replace a new Whirlpool pump.
Hope you figure it out. T. Wood CFE Plumbing
Posted on Oct 29, 2009
Testimonial: "I got this after we figured it out, but you were totally RIGHT. It was the GFI switch. You are very talented. Thanks much."
  • Tfittz Dec 11, 2010
    We have a similar situation, however it stops working when full tub of water. Use to work, did some floor work in and around tub panel and next thing it stopped. We already checked reset buttons w no luck. We believe the hose you refer to is culprit but why work without water or low water level and not when tub full?
Daniel
    New Friend:
  • 3 Answers
Ok it could be about 3 things the air tubing id disconnected from the back of the air button .the pump motor is defective or the g. f. c. i receptacle or breaker is tripped. sometimes the g.f.c.i. receptacle is in the mater bath closet or just in the master bath. and a lil bit of the time it is just outside the bathroom in the bedroom ! if you have a g.f.c.i breaker then turn it all the way off and all the way back on to see if this turns the pump back on after you fill the tub up all the way over the jets. some times when you do not use the pump, it will freeze up from non use.hopefully the home builder has an access hole to check the motor if it is defective. alot of times the do not and you have to take the side off of the tub to get to it ! Inflatable Hot Tub Reviews
Posted on Dec 14, 2016
Mirolin jaccuzzi tubs
Air Switch Repair
It sounds like you have a bad air switch located in your motor.
The air switch is what the air hose connects to on the back of the motor or on the box on top of the motor. The other end of the air hose is connected to the air button on the lip of the tub.
This is a latching air switch and when you push the air button it latches to send power to the motor. When the air button is pushed again it opens the latch in the air switch and stops power going to the motor shutting it off.
US Parts Center
Jan 28, 2014 | Home
I haven't used the tub in a while and now when I push the jet button nothing happens. No noise, nothing. Fuse breakers are all fine.
Hi, Dayne here,
If your tub has an air switch, it could be the push button, but more likely the air switch. Disconnect the tubing from the button and give it a light puff of air. If it turns on the pump. it is the button. If not, listen and veiw the air switch as you give it a light puff again. If the switch contactors close, the switch is probably good, and it unfortunately may be the pump. Remove and have it tested after looking for a reset or manual over ride by the air switch.
Thank you.
Dec 12, 2010 | American Standard Home
Aqua glass jetted tub quit working
Hello. There are two reset buttons in the mechanical space or your tub. You should be able to access that area from the front by removing a few screws. it is not uncommon to have to push those reset buttons after a power outage. If you do need a repair I recommend that you call a store that sells hot tubs as they will have a technician on staff or be able to guide you to one. Regards, Joe
PS kindly rate my answer as helpful.
Feb 13, 2010 | Whirlpool Safety Bath Walk In Bathtub -...
Only used my Royal whirlpool bathtub about three times
My jetted tub will not work, and it used to work just fine. Nothing happens when i push the button to turn it on. Could this be a switch problem? Also do not hear the motor doing anything when button is pushed. Dou you think I just need to get a new pump??
Dec 30, 2009 | Home
Can not get the jets to work
Most of the control buttons on a tub are not electrical. These buttons are connected to an air line that runs to the motor. Sometimes an aggressive button push can literally blow the air line right off of the bottom of the button.
This problem is as easy to fix as it sounds. Find the loose air line and push it back onto the button. You will need to open up your access panel. Bring a flashlight.
Be sure to check the connection at the motor too. Good luck
Dec 02, 2009 | Home
My bathtub jacuzzi wont work. I reset the circuit breakers but nothing. I filled the tub but nothing comes out of the jets
make sure you have power to outlet that motor is plugged into,if so try pushing jet button in tub about ten times in a row quickly then on tenth push use as much force as possible and hold.if this does not work,air hose from back of button to pump motor may be disconnected.
Sep 30, 2009 | Maax URBAN 6032 HYDROFEEL AEROFEEL BATHTUB...
My jets wont turn on
All the electric power source to all jacuzzi tubs all required to be protected by a "ground fault" device. Have you noticed special wall receptacles in your kitchen and bathroom that have 'test' and 'reset' buttons? There may be a receptacle (or something that looks like a receptacle but without any slots for plugs) near the tub. Push the reset button. If the pump for the tub has an access panel, the device may be behind the panel. And last, the circuit breaker in the main electrical panel may be a ground fault type and needs reset there. Good Luck
Jul 09, 2009 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
How do I use my Whirlpool bath?
youneed to make sure that the switch is on first .their should be a switch for the tub on the wall somewhere.find the switch than push the button on the tub,also make sure that their is water in the tub that is past the jets before pushing the button on the tub.
Feb 07, 2009 | Whirlpool Home
Home Logo
12,407 people viewed this question
Top Kohler Home Experts
john h
Bill Johnson
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
