Question about Philips VR630 VHS VCR
VHS tape stuck in machine. How do you remove it ?
Posted by rick_demoss on
Jim Epptech
    Scholar:
  • 101 Answers
Sometimes you can unplug the VCR for a min. or two. Then plug it back in. This will reset the processor. If the tape does not come out, pull the top off and see if the tape is out around the Head. If it is, you have to manually move the gearing to back ever;ything up. The tape its self will not retract back into the cartage, If you can get the cartage backed out, take a pencil and on the bottom of the cartage there is a hole. Push the pencil in the hole(,this releases the spindles) and turn one of the spindles and this will pull the tape back into the cartage. The tape probably won't be any good. Tapes get stuck for many reasons. Sometimes the heads are so dirty the tape sticks to the head and maybe the tape its self is wore out. Hope this is helpful.
Posted on Nov 01, 2009
3 Related Answers
Anonymous
  • 579 Answers
SOURCE: stuck tape in vhs/tv combo
Unplug the TVCR, take the cover off, find the motor (probably on the right side of the mechanism) and turn its shaft with your fingers until you have run the tape back out. Now plug it back in and try it again with a scarificial tape. If it continues to fail, replace all the rubber belts in the mechanism.
Hope ya fix it!
Posted on Jan 08, 2008
Anonymous
  • 72 Answers
SOURCE: Tape stuck in panasonic vhs playpak
there is a wheel on the side you can turn once you open it . this should allow the carriage to rise
Posted on Jun 11, 2009
SOURCE: Magnavox VCR has a stuck VHS tape, need to remove
Well I have done it by, remove from power and wait 10 mins, then removing the cover and locating the white worm drive & motor usually at right side of tape tray, then manipulate that worm with your fingers and "Wind" it out.
Posted on Feb 05, 2010
How to remove a cassette stocked in a vhs machine?
If the VHS tape is stuck inside, and when you push the eject button, it wont come out. Then you need to unplug the VHS player, take it apart so that you can access the inside. See how the tape is stuck inside and start to take it out the best you can. Once you get it out you may have to throw away the tape if it is messed up badly, if not wind it back up. Put the VHS player back together once you get the tape out. Then try to play another VHS tape and see if it works again. If not, it may be a bad VHS player or it may be the tapes. Hope this helps. I have had to take mine apart to take a tape out, so that's how I know
Feb 12, 2015 | Televison & Video
Vhs is stuck in machine. Won't play and won't eject.
There are any number of reasons why it won't play. The loading basket is jammed, the video tape has got tangled up in the mechanical section of the vcr or the loading gears are stripped. Unplug machine and remove top, [screws side and back] if the tape is spewed carefully remove by cutting it and clean tape particles, for any other problem have a technician check it out.
Jun 28, 2012 | Sony RDR-VX530 DVD Recorder/VCR
A cassette has jammed inside my vcr machine. It will not move forward or backward Can yoy please help
Since the tape won't come out then it means you will have to manually remove the stuck tape. This involves you disassembling the unit in order to help/assist the player get the stuck tape out.
Turn of the unit and remove from the wall, get a Philip screw driver, use it to remove all the screws from the unit and take it apart.
Open the cover and you will see the stuck tape and what's hooking or preventing it from coming out/ejecting.
Now plug the unit, and turn it on. Press the eject button, as the tape tries to come out, support it with your hand so that it can come out.
Or if it happen that the cassette tape has coiled inside the unit, carefully free the coiled tape and the press the eject button.
Lastly, the moment you disassemble the player, you would see what's preventing it from coming out, then you can free whatsoever that is making it stuck press the eject button and the tape should come out.
Make sure the unit is turned off each time you want to remove what's making the cassette stuck.
I hope understand the above explanations.
Good luck.
Mar 04, 2011 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Small motorla color tv vhs tape is stuck in tv
Remove power to the set - unplug the wall outlet. Remove the screws that attach the back cover. Remove the cover. Remove the cables that connect to the VHS drive to the TV main board. Remove the mounting screws that attaches the VHS drive to the set. Remove the VHS drive. Manually turn the take-up gear which is near a motor to allow the tape to mechanically eject the tape - do not force.
Feb 19, 2011 | Televison & Video
VHS tape is stuck in the VCR. Tape will not eject, will not play or foward/rewind. The unit has been working just fine with no problems. The VHS tape has been inserted into the machine to record daily...
assuming you have power to the machine , i would suggest the ejection drive belt has stretched , 2 choices here , take it somewhere and get it fixed or unplug it from power supply and remove the top casing yourself and have a look.
Jan 29, 2018 | Toshiba SD-V291 DVD Player/VCR
A VHS tape is stuck in my TV/VHS combo unit.
I'm sorry to say that the solution as stated is not correct. This condition usually occurs because of belts that are slipping. In order to remove the tape, some dis-assembly is required. If you have not done this in the past, I would not suggest that you attempt this repair. This repair should cost about $10 in parts plus labor. It is possible that the IR LED is defective as well which can also cause this. This is a common failure and should be a simple repair for any shop.
Dan
Jun 01, 2010 | Televison & Video
Tape stuck in vhs players
Yes you can cut the tape, remove it and then go to radio shack or walmart electronics dept and get some special vhs repair tape.
Apr 27, 2009 | Sony SLV-D300P DVD Player/VCR
JVC CR-6060U Stuck in 'Search' mode
TAKE IT APART CHECK TO SEE IF ANYTHING IS STUCK,,TRY A JUNK TAPE ,,,,BLOW OUT ANY DUST ,,USE A HEAD CLEANER WITH ALCOHOL
Feb 06, 2009 | Samsung VR8460 VHS/S-VHS playback VCR
VHS carriage stuck
THERE IS A SENSOR SWITCH THAT TELLS THE MACHINE THE TAPE IS LOADED ... SOUNDS LIKE IT IS STUCK. PROBLEM IS ACCESS WITH COMBO'S. THEY ARE A PAIN TO GET AT. THE WHOLE BACK COVER TO THE TV MOST OF THE TIME HAS TO BE REMOVED,... I KNOW ITS NOT MUCH HELP BUT THE MANUFACTURES KNOW THAT... HOPE YOU CAN GET TO THE TRAY INSIDE. Joe_Rex
May 01, 2007 | Sylvania SRCD227 27 in. TV/DVD Combo
Philips VR630 VHS VCR Logo
Top Philips Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
