Question about UTStarcom CDM7025 Cellular Phone
How do i turn speaker phone on - UTStarcom CDM7025 Cellular Phone
Posted by amberwhisler on
How do I turn on speaker phone?
if there is a button that has what looks like a speaker and echo wave then press that and speaker phone will switch on
Apr 12, 2015 | Tracfone Wireless LG 440G
How do I pair speaker with phone
turn both phone bluetooth and speaker bluetooth off. then turn them back on. the speaker's light should be flashing indicating its searching for a device to pair with. as its flashing make sure your phones bluetooth is visible and searching. they will pair and your phone will tell you and the speakers light should quit flashiing and just remain on.
Oct 20, 2014 | Audio Players & Recorders
Digix BT-100 Portable Bluetooth Wireless Speaker is not recognized by my android MOTO X cell phone.
Is the speaker paired with another device?
You may try turning off the bluetooth on your phone, turning off the speaker, turning back ON the speaker and then turning on the bluetooth on your phone again. This should reset the phone to SEARCH for BT-100.
Once you SEARCH for available devices you should see BT-100 on the list. Select BT-100 and it should pair. If it does not CONNECT be sure to press BT-100 again to connect. The speaker will BEEP, indicating that the speaker and the phone are now connected.
If you continue to have trouble feel free to contact the manufacturer at [email protected] or going to http://www.contelusa.net
Mar 01, 2014 | Digix BT-100 Portable Bluetooth Wireless...
Does this phone have speaker phone, and if so how do i turn it on?
Yes, there is a speaker option. Holding the phone in your hand look down to the lowest row of buttons - below the * 0 # buttons. There are four buttons: from left to right they are SPEAKER; PAUSE/REDIAL; REMOVE/MUTE; and, INT (INTERCOM.) Pressing the left/SPEAKER button one time turns on this feature. Pressing this button turns OFF this feature. Hope this was helpful.
May 11, 2011 | Vtech 5.8GHz Cordless Phone with Digital...
How to turn on speaker phone
hi
you can turn on the speaker only when you are making a call.in call.just go to option and select the turn on the speaker.now your speaker phone is turned onn.
thank you
Dec 17, 2010 | LG Ally Cell Phone
Can not turn off speaker phone
take the battery out..reset the phone..otherwise the speaker should go off with the end of the phone call.
May 11, 2010 | Motorola Mobility RAZR V3i Cellular Phone
Got the phone about 2 monthes ago...after a month the speaker stopped working, rebooted phone speaker worked again...now the speaker has cut off and rebooting doesn't help...any thoughts?
does the speaker indicator turn On or the indicator is also not turning on? seems that the speaker is damaged and you need to replace it.
Jul 01, 2009 | Cell Phones
How do i turn on the speakerphone?
there is a button on the side of the phone with a picture of a speaker on it, it is right under the camera button. if you hold the button with the speaker down for a few seconds the speaker phone will turn on, make sure the phone is open when you do this and you follow the same steps to turn the speaker back off
Nov 28, 2008 | Samsung SCH-u340 Cellular Phone
Speaker turn on
this phone will only go into speaker phone mode while a call is connected press the center feature button to turn it on and off.once it is in speaker mode you can adjust the volume with the buttons on the side
Aug 03, 2008 | LG C2000 Cellular Phone
UTStarcom CDM7025 Cellular Phone Logo
21 people viewed this question
Top UTStarcom Cell Phones Experts
Marvin
Marvin
L Vincent Testa
L Vincent Testa
Andrew Taylor
Andrew Taylor
Are you an UTStarcom Cell Phone Expert? Answer questions, earn points and help others
