My StreetPilot c340 does not respond correctly when I touch the screen. eg. I can select my state (Alabama) and it will bring up favorite locations. I can touch a number and it brings up a different number. Is there a soluction I can use?
If your StreetPilot c300 or c500 series device is no longer acquiring satellites please read the article linked below to ensure that this is not being caused by something in your environment:
If after reading the above article your unit is still having problems, please ensure that your unit's software is up to date. You can do this by using our WebUpdater® program.
If you have tried all of the above suggestions and your unit is still not acquiring satellites, you can perform a master reset by doing the following: Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
Start with the unit powered OFF and unplugged from power.
Touch and hold the bottom right corner of the touchscreen.
Power the unit ON and continue pressing the screen until a new message displays, "Do You Really Want To Erase All User Data?".
Touch Yes and go through the set up again.
Take the unit outside and let it set with a clear view of the sky for 3-5 minutes to acquire satellites. If the unit still does not acquire satellites after this, please contact Garmin Product Support.
There is a small pinhole on the bottom or right hand side of the unit for reset. Try hitting this with a paper clip or pin. If that doesn't help you may have to take it into a store.
Hello there: please follow these instruction and this should help if not let me know and i willcontinue to get you more information for you nstructions
Step 1
Calibrate
the screen of the Garmin StreetPilot C340. If the touch screen does not
seem to respond when you hit it with your finger or a stylus, you may
need to calibrate it. To do this, turn the unit off and then hold down
the "Power" key for approximately one minute. You will see a
calibration screen come up that will recalibrate the GPS unit.
Step 2
Reset
the Garmin StreetPilot C340. If your GPS unit is not responding or is
stuck on a particular screen, it may need to be reset in order to
operate. To reset, remove the face plate of the unit by gently prying
it off. Locate the "Reset" button under the face plate and press down
in order to restart the device.
Step 3
Change
the fuse of the Garmin StreetPilot C340. If the fuse blows on the GPS,
you will need to make a replacement using an ACG/3AG 2 amp fuse.
Unscrew the adapter cord at the end and remove the fuse found there.
Put in the new fuse to see if this returns function to the unit.
Step 4
Update
the software for your Garmin StreetPilot C340. If the GPS is not
providing you with correct directional information, you may need to
update the software or download new maps onto the device. Connect the
Garmin StreetPilot C340 with the USB cord to your PC and log on the Garmin website for available updates.
I am the one who answered your first question. A reset will bring the GPS back to factory specs as when you opened the box. You may lose all your POI, and favorites when the unit is reset.
Remove the face cover (GENTLY pry it loose by using the fingernail groove directly under the GARMIN logo), press the RESET button, then re-attach front cover... this is covered in the owners manual, also available online at garmin.com /support /downloads
Ok, you've tried a reset, but have you tried a Master Reset? Doing this WILL ERASE ALL OF YOUR FAVORITES, but it may help. Turn the unit off. Press the "On" button with your finger on the bottom right of the screen at the same time. Release the "On" button, but keep pressing the screen until the unit asks if you're sure you want to reset all data. Press "Yes". See if this helps.
Opdave, turn it on, and go outside and let it see the satellites... My thought, the device has not recognized it is in a new location,,,, else Good Luck GB_C
