HP Compaq Presario CQ50-110US Laptop Logo
Question about HP Compaq Presario CQ50-110US Laptop
Have a Compaq CQ50 and don't know the BIOS password....how to i reset it
Posted by jharris541 on
Shankar Jha
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 196 Answers
Remove CMOS battery and after 5 minutes install the CMOS battery ,it will crack the bios password,you might be knowing where the CMOS is else i am just guiding you...i am providing you link to the manual that will give you 100% information for you CQ50
MANUAL
click on the link above
thanks and regards
kindly rate this solution
Posted on Oct 28, 2009
  • odonnell
    odonnell Jun 13, 2014
    Shankar Jha, you cant crack the bios password by removing the battery, thats a very long short
Anonymous
FYI: The CQ50's have removable cmos batteries. They are behind the Hard Drive access door.
Posted on Dec 17, 2009
odonnell
    New Friend:
Guys post helpfull tips, you cant just remove The CMOS battery and wallah, and the password is gone, there are other ways which am also trying to find
Posted on Jun 13, 2014
5 Related Answers
Anonymous
  • 77 Answers
SOURCE: how to reset bios for laptop compaq presario cq50
You can do it the hardware "way" where you have to open your laptop and remove a battery inside the computer or can do it the software "way".. I would recommend you the software if you doesn't have tried to open a laptop before..
Download this: http://www.pccmos.com/download/PCCMOSCleaner.iso
And guide for how to set it up: http://www.pccmos.com/guide.html
Posted on Mar 11, 2009
Anonymous
  • 30 Answers
SOURCE: reset power on bios password on compaq 2200
theres a small battery in you computer you have to pull for like 5 minutes you can find out what it looks like on youtube.com or wonderhowto.com
Posted on Mar 24, 2009
Anonymous
  • 233 Answers
SOURCE: MY COMPAQ PRESARIO NOTEBOOK CQ50 100EM - DOES NOT
The issue might be with the hard drive. I recommend you to test the hard drive.
If the hard drive test fails, then it is confirmed that the issue is with the hard drive of your notebook.
Click on Testing a hard disk in HP notebooks in the below link to test your hard disk:
http://notebook-solutions.blogspot.com/2009/06/all-about-hard-disks-in-laptops.html
You may also try the steps in the below links:
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?rule=23287&lc=en&dlc=en&cc=us&product=3752686
http://notebook-solutions.blogspot.com/2009/05/notebook-solutions-notebook-solutions.html
Follow the steps from No Boot or no Power in laptops
Posted on Jun 27, 2009
Anonymous
  • 98 Answers
SOURCE: crack bios password on compaq nc6320 - please
My best suggestion is to call Compaq or HP for assistance regarding on this. Thank you.
Posted on Oct 09, 2009
Testimonial: "thanks - I like to do things myself, but I will call them - "
krbshg
Banjade
  • 430 Answers
SOURCE: compaq 6510b reset cmos/bios password
try this: Make sure the battery for the notebook is out in step 8
the procedure to reset the CMOS/BIOS is in the maintenance and service guide on page 46.
Follow these steps to clear the password:
NOTE: These steps also clear CMOS.
1. Shut down the computer. If you are unsure whether the computer is off or in Hibernation, turn the
computer on, and then shut it down through the operating system.
2. Disconnect all external devices connected to the computer.
3. Disconnect the power from the computer by first unplugging the power cord from the AC outlet and
then unplugging the AC adapter from the computer.
4. Remove the battery (see Battery on page 48).
5. Remove the real-time clock (RTC) battery (see RTC battery on page 68).
6. Wait approximately 30 minutes.
7. Replace the RTC battery and reassemble the computer.
8. Connect AC power to the computer. Do not reinsert any batteries at this time.
9. Turn on the computer.
All passwords and all CMOS settings have been cleared.
Posted on Jul 27, 2012
2helpful
2answers
Cq56 reset bios password
You will have to remove the power cord, remove the batteryand remove the CMOS Battery that is located on the motherboard. On mostcomputers you will have to take the laptop apart to get to the cmosbattery. On some systems it looks like a silver nickel that you will needa small flat head screw driver to pop it out. On other systems it will beinside a vinyl covering and has a cable that plugs into the motherboard. Once you remove the CMOS Battery, let it sit for an hour or two then put itback in and put the laptop back together. Boot the machine and you'llprobably have to go into the Bios or System Setup because the system will haveforgotten the date, time and password.If the password is not reset then you might have to go and remove a Pin from the password jumper on the motherboard. I would consult the user manual and see how to do it.
6helpful
6answers
I forgot my BIOS password and i can't access it becos i don't know the password.
HP Spare Key can be used to reset BIOS password. It is provided by HP Corporation. So when you forgot BIOS password on HP computer, just download it and get perfect BIOS password reset.
How to reset HP bios password with Spare Key or other ways?
Please refer to reset HP Elitebook password. In this passage, you also can learn how to reset Windows administrator password easily.
http://www.isunshare.com/windows-7-password/reset-hp-elitebook-password.html
My sister gave me a Compaq evo computer. When i turn it on it goes right to a screen that says Power-on password with a picture of a key. She doesn't know what the password was and it doesn't let...
It seems to be BIOS password, if you don't remember or don't have the BIOS password you have to reset the password by opening your CPU cover and removing the CMOS coin battery, this will reset the BIOS password but dont forget to return back the battery and start using your PC.
Regards,
JJ
1helpful
My hp G60 LAPTOP WAS STOLEN ON SUNDAY BY 2AM,I DON'T NO IF IT CAN BLOCK IT SO THAT THE THIEF WOULD NOT BE ABLE TO USE THE LAPTOP
Only if you have BIOS password set. In the past, BIOS passwords can be reset by removing batteries and shorting pins. But these days, the NVRAM chips that holds the passwords needs to be physically desoldered and replaced, which makes it very difficult and costly.
Windows passwords can be cracked easily. Hard drive passwords are also near impossible to crack and protects your data, but hard drive can be replaced easily making the laptop usable.
So if didn't have BIOS password set, then you're pretty much out of luck.
I need reset bios password Notebook HP Compaq 2710p
I know some methods to reset bios password.
1. The best and easiest method: Close OS and shut down the electricity power of computer. Open your computer box, take out the cmos battery from the mainboard. Then the bios password will be reset to blank. Put it back after a few minutes.
2. Follow some hard tutorials, it is difficult to do. It is better that you are a expert. For example this tutorial: reset BIOS Password?
So I would suggest you the 1st method. Hope it helps.
How can i brake the password on my laptop presario cq50
passowrd for windows or password in bios , if password windows u to soft password recovery and boot from cd to remove.
If pass bios u can't , much sent to brand to do
Compaq presario cq50-215nr password reset
please remove the cmos battery then place again after 30minutes.
2answers
Forgot password......windows xp compaq s6000cl not a notebook
if you forgot your password restart in bios then advanced or security and user passwords you can change
bios administrator password i am not sure if you can change or remove if you forgot it
you can also restart in safemode and follow instructions i gave you earlier
let me know
NEED APPARENTLY TO CHANGE MY BIOS PASSWORD
You can try using this to Reset / Remove this BIOS Password >
http://www.ntfs.com/boot-disk.htm
1helpful
2answers
How to resets bios for compaq 2514 at
Why? What happend? Is it asking for a BIOS password?
If it is asking you have to short two jumpers on the systemboard to have it reset.
If not, just go in to BIOS by pressing F2 then restore or optimize default settings on BIOS.
Hope this helps...
Top HP Computers & Internet Experts
Mehandi Husain ...
Marvin
Marvin
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
