The problem could be in the adapter to the video card. There are different types of DVI connections. If the adapter does not have the proper set of pins then the card will not recognize that a monitor is connected at that port. Monitors themselves have no bearing on whether a single or dual monitor set up will work or not. Digital Visual Interface Follow this link, it may help you determine if the adapter you are using is correct for the graphics card.
If your SP1 camera cannot recognize the micro SD card, please be sure you are using a card between 4GB to 32GB, class 10 speed. If possible, please try another micro SD card to be sure that the card that is not recognized is not defective. If you are using a card with correct specifications and it is not recognized, then the micro SD card port on your camera may be defective. Please contact Intova directly via email: [email protected] or call us at 808-837-0074 for customer service/warranty coverage. Thanks.
the video card you used have a capability for dual monitor..so 1st thing that you need to do is to make sure that the computer recognized the 2nd monitor and activate dual monitor capability on the nvidia panel..after that on your tv select the proper source(like VGA, HDMI1 etc.) on which you'll be able to see the the video from the computer to your TV..
You may have tried this & I missed it.
For htis new cardto work, you need to DISABLE the on-montherbord video.
Go to BIOS Setup and you will find a spot where you can disable onboard video.
Now Mboard will recognize your new video card.
1st try to exchange the cards in the slot.
2nd try another card
3rd ur RAM slot may not be ok
4th ur RAMs may not be compatible
5th ur new RAM card may not be ok
use same type of RAMs, and same size...
if u have 256, add 256
if u ahve 128 add 128
if u have SDR then dont add DDR
getting compatibility is little difficult...
some times no combinations can work...
note...technology keeps changing...so a old RAM card that was bought years ago may not be compatible with a new RAM card....
even i got all my old RAM cards(256+128) removed and got 2 - 512mb of the same type fixed...even i had issues with my RAMs for 6 months...
Go into Control Panel and choose the Display option in XP or Personalization option in Vista. Find Display settings.
Then check the Extend the desktop onto this monitor box to activate the 2nd monitor.
there is a small button between the 2nd memory card slot and controller inputs(where u plug in controller). Press and hold that button. If that doesn't work there is eitgher a problem with guitar or a connection interference with it.
