What is default setting for the pin code for my Alba Freeview box? The model number is DV3. I have tried to rearrange the channels to no avail need to revert to the factory settings but need the pin code to do so.
I have set up wrong and need to go to defaults blind so to speak as cant see what i'm doing on tvI have set up wrong and need to go to defaults blind so to speak as cant see what i'm doing on tv
You can't post conmments that contain an email address.
If you have the user manual you will probably find there is a default password or a default PIN number programmed into the box at the factory that you can keep using or change as you see fit.
My Freeview box uses 1 2 3 4 as the PIN. Lots of old video recorders were the same.
If the remote control have set-up codes with Alba freeview, you can.
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order.Pull up older posts. Surf the site with patience. http://remotesearch.blogspot.com/ http://electrohelponline.blogspot.com/
Has the box got a scart socket? If it has connect the VCR to that via a scart lead. If the alba has two scart sockets then use the second one. When recording set the channel as AV1 or AV2. If you don't have enough scart sockets to connect your TV, VCR and Box, then get one of these Scart Switching Box from places such as Amazon or Argos.
Ok this info does not seem to be anywhere so here goes.....
Grundig gud300hd and others of same build alba ect...... set top box pin reset
UNLOCK CODE1. Press MENU and go to Settings and press OK.
2. Go to Parental Control and press OK. The 'Enter the PIN Code' menu will be displayed.
3. Press i (information) button once then enter 4000.
4. Go to Change PIN Code and press OK.
5. Press i (information) button once then enter 4000.
6. When it prompts for New PIN enter the desired PIN number using 0~9 keys. Enter it again to confirm.
Most of the ALBA equipment uses a default of 8's, and some people have reported that 1's are their default code. I have an STB300HD that's just been brought to me for checking, the default code for that model is 8888. Another one I had looked at/repaired last month, i cant remember the model but it was still an ALBA, had 888888 as its code. As far as I am aware, you can type the wrong code as many times as you like, i'd tried over 10 codes on the STB300HD before finding the correct one and it never gave any warnings or total lock-outs. :) Good luck.
(just to help in Google searches for others owners)....... ALBA STB300HD parental lock default code = 8 8 8 8
DV3 is actually DVB meaning Digital Video Broadcasting. The stylised design of the DVB symbol makes it look more like DV3. If the TV has the DVB symbol, then it has a digital tuner and can receive digital channels, i.e. Freeview.
If you need assistance with tuning the Freeview channels or have further questions, please let me know the model number of the TV. This can be found on a label on the back of the TV.
