Question about Panasonic Televison & Video
Hisense tv code needed
Looking for the code I can put into the panasonic dmr-xw350's remote to operate a hisense tv.
Posted by linuxtemp on
Norman Worley
    Genius:
  • 1,273 Answers
Even though this problem is a year old, I thought that I would share my solution for Remote codes for a Verizon FIOS.
I tried asking Verizon, and Hisense for a code that would work as the published codes did not work to program my Verizon remote. No answer from either.
I accidently discovered that the codes listed for LG worked, in fact the first code listed worked. I surmise that Hisense uses the same codes as LG.
If you are at wit's end then try the LG codes.
By the way. I tried stepping through all codes several times but no success with the Verizon instructions. The fact that the LG codes worked, indicates that the Verizon solution is wrong.
Posted on Jan 19, 2012
Anonymous
    New Friend:
I had a panasonic video/dvd player and a hisense tv. tried all codes and 12 worked for me. can't hurt to try
Posted on Apr 06, 2010
Panasonic dmr xw350
if it uses a SATA hdd it maybe the drive is faulty & is now not booting at all. most will take a normal pc SATA hdd but check what the max size your unit can take as they have there own format & you may make the drive un-usable in a pc again. i would say get a second hand 160 - 250GB drive and try it out. as they are cheap 2nd hand.
My Onkyo DR90 DVD Remote Will Not Operate Components
Your Onkyo DR90 DVD Receiver remote control does not have universal remote functions, and cannot be (easily) programmed to control a Panasonic DMR ES15. Your DR90 remote does have a limited learning function, but it is designed to learn the codes from your TV's remote to control the TV. Only the following buttons are programmable by the TV Learning function:
I hope that helps.
______________________________________________
Onkyo DR90 DVD Receiver User Manual Download.
Apr 14, 2010 • Onkyo DR90
What is remote code for panasonic dmr ez48v
This is the code-Panasonic 100, 101, 125, 130. You can also check this link for other relevant information-http://www.universal-remote.net/panasonic.html
2helpful
Panasonic DMR-XW350 Network enabling firmware Upgrade.
The web page seems to have a problem in its Javascript that jumps to the page for each location.
You can get around the problem by editing the support page URL, just replace index.html at the end of the URL with one of the options:
For example for New Zealand, change the index.html to nz.html: so the following
http://panasonic.jp/support/global/cs/dvd/download/xw350/index.html
is changed to:
http://panasonic.jp/support/global/cs/dvd/download/xw350/nz.html
The options in the Javascript are listed as follows:
<option value="au.html">Australia</option>
<option value="nz.html">New Zealand</option>
<option value="uk.html">UK</option>
<option value="fr.html">France</option>
RCA TV Code
Can you tell me the Full Model number for this TV Please
5helpful
My remote
Sounds like you've accidently switched the remote to operate under remote code 2 - to switch it back to operate under remote code 1 you need to hold down the "Enter" button on the remote, and while doing that press the "1" key.
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
