Acer Aspire 3000 Notebook Logo
Anonymous Posted on Oct 28, 2009
DVD player stuck on region 1
I have an Acer Aspire 3000 laptop.
My DVD/CD player has run out of region changes, so I can only play region 1.
Is it possible to override this so I can play other region DVD's.
Pete
  • 1 more comment
  • Anonymous Jun 30, 2020
    if your drive fails buy a region free drive.
    many drives can not be changes or limits to 3.
    hack the drive.? (go to videohelp.com) read.https://www.videohelp.com/dvdhacks
    read if your drive can be hacked.
    or buy a new drive.
    toss coin
  • Anonymous Aug 01, 2020
    ask acer.com
    1: some are 1 region only for life.
    2: some you can change 3 to 7 times ask maker.
    3: some are hacked. google hacking DVD, endless topic and endless drive models made , all with different solutions if at all, or then you brick the drive doing hacking...
    4: or learn to shop for region free drives, we do not know where you are, my wild guess USA.
    but shopping varies by country, as you will learn customs inspectors in many countries block entry for them being illegall(sic) in your country. for sure USA>
    they block mostly real stores importing in MASS
    and you can goggle that and see the FINES .
    but EBAY buys are not inspected,so there you go.(dvd topic only)
Anonymous
Level 3:
  • Acer Master 32,281 Answers
  • Posted on Oct 28, 2009
Anonymous
Acer Master
Level 3:
Answers
32281
Questions
Helped
7905686
Points
102259
If you want to play DVD from any region you maybe able to upgrade the firmware to make it region free BUT if you make a mistake or installed the wrong firmware the player will be a piece of junk.
The best solution to make the player region free is to install a piece of software that allows you to play DVDs from any region. There are several available on the Internet but my favourite is DVD-Region Free
www.dvdidle.com/dvd-region-free.htm
Testimonial: "Great advice, dvd region free is a saviour. Thankyou so much. Pete."
    you can brick a drive easy. hacking it.
    one more choice, buy USB+DVD drive region free.
    then not wreck the original DVD drive.
Adnan Bhatti
Level 3:
President:
  • Master 1,188 Answers
Adnan Bhatti
Master
Level 3:
President:
Answers
1188
Questions
Helped
410005
Points
3822
Yes, it is possible. There are two methods: hardware and software.
I will only help you with the software type as it is easy and the changes can be reversed.
For software hacking there are many tools available. However, I enlist here two of the most popular and easy.
The first one is DVD43, it is free and may work for you. Click here to get more information and download.
The second one is a commercial software but allows a 21 days trial period. The name is Slysoft AnyDVD. Click here to get more information.
If the above tools are not helpful, it means that your drive has been locked permanently. It can be reversed by a firmware change. Be advised that this is not an easy process and it can render your device unusable if performed incorrectly.
If you take the risk, click here to get more information on flashing your DVD-ROM.
Are Acer z5600 dvd players multi-regional?
Open the properties of the DVD/CD rom, Hardware Tab, select DVD/CD rom device, Properties, DVD Region, select Region. READ CAUTION CAREFULLY.
2answers
How do i return my coputer to region 1
click start control panel administative tools computer management disk management right click on your cd/dvd drive select properties you will see dvd region tab to change it
remember you can only change it a certain ammount of times
hope this helps
Hi,MY ACER 4720 Dont play any DVD but playing cd /copying CD is fine.When i checked its property,Driver shows as CD ROM driver.i did not find any dvd driver.Could anyone help
The DVD player may be set to a Region that does not match the Region code on the DVDs.
To changethe Region code on your DVD player, open Control Panel - System - Hardware -Device manager, and click on DVD/CD ROM drives, then right click on the DVDdrive and click Properties then click on DVD Region.
You can enter a new region and it also shows you how many changes have beenmade.
NOTE you can make only 4 changes and the player will lock permanently on the4th change.
If you want to play DVDs from any region you maybe able to upgrade the firmwareto make it region free BUT if you make a mistake or installed the wrongfirmware the player will be a piece of junk.
The best solution to make the player region free is to install a piece ofsoftware that allows you to play DVDs from any region. There are severalavailable on the Internet but my favourite is DVD-Region Free From: -
4helpful
2answers
How do I set acer aspire dvd region to read all dvds?
Click Start
Click Settings
Click Control Panel
Click System
Click Hardware
Click Device Manager
Click the '+' to the left of 'DVD/CD' branch of the hardware tree.
Double-click your DVD device.
Change the region.
Note that you can "change region" only about 5 times, before the DVD will "lock" into a specific region.
1helpful
Acer aspir532 series cd/dvd 'region' problem
is the dvd from the usa region? if it is just reset your region on your dvd player
1helpful
Hoe do i make my acer aspire 5315 laptop region free
To change the Region code on your DVD player, open Control Panel - System - Hardware - Device manager, and click on DVD/CD ROM drives, then right click on the DVD drive and click Properties then click on DVD Region.
You can enter a new region and it also shows you how many changes have been made.
NOTE you can make only 4 changes and the player will lock permanently on the 4th change.
1helpful
2answers
DVD drive ''Free'' Region code does not play Region 1 DVD
You cannot see region 1 movies unless you change the region code, its designed this way as an anti piracy measure.
Exteral DVD 1 from India & 1 from the USA neither paly DVDs
What region is your DVD player locked on and what region DVD disc are you tyying to play?
Cannot play region 1 dvd because the dvd rom drive was set to region 4
You need an Apex AD-500W DVD Player. If after you Google it you cannot figure it out, there are still a couple folks selling them on eBay. Good Luck!
MY CD BURNER ON MY ACER ASPIRE 9410 I USE My ZUNE SOFTWARE and tried windows media player but it burns the cd but when i try to play it it doesn't play at all on anything
Check if the DVD region on DVD burner proprierties is set to same region of your player OR use sw like ShrinkDVD to create Region free DVD.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
