Question about Sharp Wizard OZ-650PC
I have many Wizard oz-650pc. I have been
I have many Wizard oz-650pc. I have been inputting a great deal of information into one of these organizers. I want to back it up using the program Rupplynx version 1.2. However it starts to back up but then after a few minutes I get an error message. I need help backing it up to my computer. Thank you
Posted by gfbiztobiz on
5 Related Answers
Anonymous
SOURCE: SHARP WIZARD OZ-590A DATA ORGANIZER
Turn on your organizer and touch the Clock Icon with your stylus. Just to the right of the bold heading on the top of the screen is a downward arrow. Touch the arrow with your stylus and a screen should come up with with six different modes of your choice. Touch the Home clock. Now touch the Edit on the bottom right hand corner of the screen. Touch the left solid arrow on the bottom of the screen enough times to bring you to the Country at the top of the screen. Touch the solid up or down arrow until you come the USA. Touch the solid right arrow unil you see the USA city field. Now touch the solid down arrow until you come to your city. Touch the solid right arrow once and the hour should be highlighted. Enter your hour. Now touch the right arrow to enter the minutes. Continue with the right arrow to fill in all the values and touch am or pm. Finally touch save or enter. The little smilly face is for daylight saving time which is touched on in the summer time. Hope this helps you, [email protected]
Posted on Jul 22, 2007
mattozan
Matt Jurach
  • 555 Answers
SOURCE: HAVE SHARP WIZARD ORGANIZER MODEL
A manual for your device can be found here.
Posted on May 06, 2008
Anonymous
  • 101 Answers
SOURCE: Sharp oz-770
Have you tried transferring with the original software for the device? Here is a page with download links for the original software, also here is a free trial software that claims it can transfer this data.
Posted on Jul 17, 2008
Anonymous
SOURCE: Replace battery in Sharp OZ-8000 pda.
unscrew 3 little screws at the bottom cover using jewelry phillip driver-remove the cover- you will see further instructions inside the cover. This model requires 5 batteries CR2032 (4 for main memory-1 for backup memory)-Hope it helps.
Posted on Jul 18, 2009
Anonymous
SOURCE: How do I back up my Sharp OZ 570
i change new Batteries and then not appear anythint on Screen. pls help.
Posted on Sep 25, 2009
Looking for software for OZ-730. Found that www.mywizard.com is no longer an accessible site.
CALL thewizardshop.net 803-736-4382 they have software and sharp organizers.The wizardshop can help you with ALL your Sharp Organizer needs.
Cords,software for Windows XP and 7. They have Sharp OZ-730,OZ-770 and YO-520. They also repair ALL Sharp organizers with a keyboard.
www.thewizardshop.net
803-736-4382
3answers
Transfer OZ-750 Data to Computer
Hi Pat,
and with the indulgence of otacon and Ekse...
You would need the Docking Module and the attached COM1 cable/plug.
You might find this page/document very informative if not interesting. Should you need the software (Day-Timer Organizer), it is available here. Additionally, a Q & A about OZ750 is here.
Hope this be of additional help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
2helpful
Sharp OZ-730 sticky keys
I have a a Sharp yo-480. I've fixed sticky keys many times. I back-up data in the organizer first. (yo-480 doesn't have a flash memory) then carefully dissasemble unit. Lift out rubber keypad and use WD-40 to wipe circut board and keypad. It's the sticky residue that makes the keys stick
Forgoten password
If you forget your password, there is no way to bypass the Secret function or enter a new password without losing all data marked as Secret.
If you forget your password, you will not be able to
unlock the Organizer and access your secret information. If this happens, you will have to delete the old password to be able to continue to use the Secret function. This will also delete all entries marked as secret.
The instructions on how to do this are here Page 56:
http://74.125.93.132/search?q=cache:SOGXtoq14ZkJ:www.sharpusa.com/files/org_man_OZ730_750.pdf+Sharp+Wizard+OZ-730+recover+password&cd=1&hl=en&ct=clnk&gl=ca&client=firefox-a
6helpful
2helpful
2answers
Syncronizing the data from a Sharp OZ-650 to a new computer
A quick and dirty method of getting your data to near flat file format is to find a computer with the old RS-232 serial port and use a third party software called "Rupplynx" v 6.0 or 6.1 to download the data from the Wizard to the Rupplynx software on the PC. The backup/extracted files that you create with this software will be binary but the address book, memo etc data portion of the file will be ASCII text that is readable (beware, even the secret entries are readable so you will have to guard the computer that the files are on). A better but slower way is to copy and paste the uploaded and displayed data text in the Rupplynx 3rd party software to a Word document or plain *.txt file. I did this for the most important data since I also had about 10 years worth of memos and contacts.
I copied the whole subdirectory with the binary files from a windows XP computer that had an RS-232 port to a Windows vista computer and the program ran fine so that I could get the data into a compatible format such as Word or plain text file format. (via copy and paste) Rupplynx also has an export option to export to different file formats...
1helpful
Sharp Wizard OZ-730
Hi, I has this same problem but I found in the user manual this instructions and works ok: 1. Press and hold the Start key.
2. While holding down the Start key, push the RESET button
on the bottom of the Organizer using a pen or some other
pointed object. The following message will appear.
"Do you really want to initialize the organizer's memory (this will delete all data)? Yes:[ENTER/No:[ESC]
3. Press to initialize the Organizer.
The message .Working... Please wait.. appears while the
Organizer proceeds with the initialization procedure.
The Welcome message then appears.
2helpful
2answers
Sharp wizard oz-730
Hi, I has this problem but I found in the user manual this instructions and works ok: 1. Press and hold the Start key.
Can you reset the passcode onSharp OZ-650PC?
Just use the menu key and delete secret data..this erases the password and keeps all other data.
Sharp Wizard OZ-650PC Logo
Top Sharp Computers & Internet Experts
Lawrence Oravetz
NOEL
NOEL
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
