Hello. Noises are common when using a two-in-one washer and dryer, as clicking or whirring is part of the cleaning process during the transition to the next cleaning process. The GE Spacesaver washer and dryer combo uses a top-loading washer stacked beneath the front-loading dryer, and uses an agitator that makes noises throughout the spin cycle. Although whirring or clicking is normal, other noises or malfunction indicates a problem with the washer that requires minor troubleshooting. Professional repair is necessary if the washer continues to experience problems during the spin cycle, as there may be a problem with the washer's agitator. 1 Open the washer's door and check the balance of the load's clothes. Clothes that are unevenly distributed around the agitator cause excessive shaking and result in an imbalance during the spin cycle. Reduce the load's size by removing clothing if the washer's drum is overloaded. 2 Push "Start/Pause" to pause the spin cycle and turn the washer's cycle knob to the "Off" position. Turn the knob to "Spin Only" and press "Start/Pause" to reset the cycle. 3 Turn the wrench counterclockwise or clockwise around the unit's legs to adjust the appliance's balance. The legs are adjustable with the help of a wrench to ensure the unit does not shake while in use. An unleveled unit shakes as it spins, and causes excessive squealing or rattling as it attempts to dry the clothes. 4 Touch "Start/Pause" on the front of the washer's control panel and unplug the washer/dryer unit's power cord from the electric oultlet. Wait two minutes and plug the power cord back into the electric outlet. Push "Start/Pause" to resume the spin cycle. Thanks.
can you hear it trying or does it try with a grating sound,most of these have a plastic drive coupler underneath the agitator and this or the thrust bearing could be your issue,you need to remove the agitator parts first(and run a wash cycle without any clothes in the washer) and see if this is the problem,as with the agitator off the stem(both inner and outer) should run when held by hand during any cycles and there should be resistance as in no slipping during holding by hand,then if you still have problems then its further below this area
the agitator shaft could be stripped out. does it sound like the motor is working during the wash cycle or is it just idle? This is a common problem with ge washers the agitator strips out on the transmision and needs to be replaced.
If The washer won't agitate Check to make sure no clothing got wrapped around the agitator. Check the lid switch, timer, and drive belt, other potential causes, such as a bad transmission or bad agitate/spin solenoid, but they are much more involved.
if the washer won't spin, the lid switch, timer, drive belt, transmission, or agitate/spin solenoid could be the cause here as well. Sometimes if the load is unbalanced or too heavy, the washer won't spin. Take some of the clothes out and try the spin cycle again with a lighter load.
Here are the steps to replace the agitator. 1: Take the fabric softener dispenser off and pry off the agitator lid. 2: Use a socket wrench with an extension bar to remove the stud and seal. 3: Remove the agitator top and bottom. 4: Check the agitator clutch assembly (located in the agitator top) for excessive wear. 5: To replace, just reverse the directions.
remove the agitator and inspect the main shaft on the gear box.and
check the belt underneath.if the shaft is bend you will need a new
gearbox. hope this helps.
remove the agitator by first taking off the softner dispenser at the top of the agitator and then look down inside. inside you will see a half inch head bold. remove bolt and lift agitator out.
it will more than likely be a bra wire stuck between inner and outer drum it will only sound when clothing is in it due to the weight of clothing and water so it wont be heard with just water init or by pushing it around by hand only thing u can really do is eiether strip it yourself or by getting an engineer in but what i would do is leave it after a while it will dislodge itself and go into the pipe underneath the washer in the pipe that is in the middle of the drum check this when the sound stops love
