Question about Lenovo ThinkPad T400 Notebook
How do I lock the touchpad of the Lenovo Thinkpad?
Posted by ktizme on
muebe
    President:
  • 1,015 Answers
You can go into the device manager on windows from the control panel and right click on the touch pad device listing. Then select disable this device. This will stop the touchpad from working until you re-enable it again.
Posted on Oct 28, 2009
1 Related Answer
Scott P
  • 1087 Answers
SOURCE: How do i disable the touchpad of my Lenovo T410
Well if the bios is not password protected or u know the password there should be an option to disable in the bios.
Posted on Jun 24, 2010
The cursur jumps all over the place when I type in lenovo e530
Make sure you disable or turn off the touchpad when you are typing. You are accidentally hitting the touchpad when typin that causes your cursor to be erratic. I suggest to plug in a mouse and disable the touchpad.
Oct 16, 2014 | Lenovo ThinkPad Edge E530 325978U 15.6"...
Keyboard unlock
Like most modern laptops, IBM/Lenovo laptops feature a built-in touchpad that you can use as a substitute for an external mouse device. If you experience a non-functional or "locked" touchpad, then you have one of two possible problems; either the touchpad's drivers are corrupt or a user has manually locked the touchpad. In either case, you can unlock your touchpad and restore it to functionality quickly.
Open your web browser and paste the following URL in the address bar:
Click the "Download" button and then click "I agree" to save the Lenovo touchpad driver installation file to your computer. Double-click the EXE file that you downloaded. Doing so opens the driver's installation wizard. Follow the on-screen prompts to re-install your Lenovo's touchpad drivers. If your locked touchpad is due to a corrupt or outdated device driver, then your touchpad is now unlocked and functional. Activate Touchpad Hold the Windows logo key and press the R key to open a run command box. Type "control mouse" in the box and press Enter. The Mouse Properties control panel window opens. Click the "Device Settings" tab. Click the Lenovo Touchpad in the "Devices" list and click the "Enable" button to activate the Touchpad. Click the "OK" button to save your changes. Your Lenovo's touchpad is unlocked and ready for use. Lenovo support
http://consumersupport.lenovo.com/vn/en/DriversDownLoads/drivers_show_120.html
Feb 24, 2013 | Lenovo Computers & Internet
Touchpad not working
This may help:http://support.lenovo.com/en_US/detail.page?LegacyDocID=MIGR-67760
Dec 07, 2012 | Lenovo ThinkPad R61 7733 Notebook
Thinkpad t510 4314 touchpad and mouse stop responding
It shows the fault of USB ports and in my point of view you need to replace with a new motherboard.
Hope it will be helpful.
Good Luck
Aug 19, 2012 | Lenovo ThinkPad T510 4314 - Core i5 520M...
Lenovo t410 touchpad stopped working
try to get the driver of ur touch pad from lenovo web site if still it not works then change it
Dec 31, 2011 | IBM Lenovo ThinkPad T410 2522K3U Notebook...
Touchpad cannot be disabled, thinkpad l412
For you to disable the touchpad of your system simply tap FN + F6 or FN + F8.
Thanks for using Fixya.
Jan 27, 2011 | IBM Lenovo ThinkPad L412 Notebook
Lenovo SL500 mouse pad want to lock in window XP. how can do that?
Hi. I think you should press and hold the Function(Fn) key then press F8 key on your keyboard to disable or enable your touchpad. If this doesnt work I think you should download first the drivers for your touchpad and then you can proceed with the steps i mentioned. Also you could disable it by accesing the device manager on your laptop then disable your touchpad. You could also do it by going to the control panel and its under the mouse settings, then from ther you can disable it.
Apr 05, 2010 | Lenovo ThinkPad SL400 Notebook
Touchpad & lower 'mouse' buttons do not work
There is a button on the laptop which re-enables the touchpad. It's either next to the touchpad, or you must hold down the Fn button and press one of the function keys at the top.
Jul 07, 2009 | Lenovo ThinkPad R60 with Wireless Wide...
T61 Laptop Keyboard Mouse Issue
ensure the trakpoint is enable in the thinkpad configuration utility
Jan 08, 2009 | Lenovo ThinkPad T61 Notebook
Lenovo ThinkPad T400 Notebook Logo
2,405 people viewed this question
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
