Question about HP DeskJet 656 Thermal Printer
Where can I purchase a power supply cord for a hp deskjet 656
Where can I purchase a power supply cord with transformer to plug into printer hp deskjet 656?
Posted by dante_frescu on
HP Deskjet 1056 supposed to be dual voltage...?
What does it say on the "brick" on the cord? Look for power specs on the cord transformer.
Dec 10, 2012 | Office Equipment & Supplies
Replacement power cord for my h/p lasejet printer
If you just need a replacement power cord then you should be able to use any similar 'kettle' plug computer power lead from a system unit, monitor etc.If you actually need a replacement power supply including the power transformer block which converts the mains voltage to the DC voltages required by the printer, then you will need to look at on-line companies who provide such parts.See http://www.aliexpress.com/store/100504/202932004-359117582/Original-AC-Power-Adapter-Charger-for-HP-Deskjet-F380-All-in-One-printer-00086.html for one such company which also shows the power lead socket.
Dec 20, 2011 | Office Equipment & Supplies
Re hp 1315 all in one the printer does not ge switched on after connecting the power cord. is there any electrical fuse which has blown off. if yes where is it located
Make sure you power cord is plugged in tightly on both the wall outlet and the transformer. Make sure the plug from the transformer is plugged tightly into the printer. If all this looks good check the outlet, or switch outlets. Then replace the power cord. If you have access to another PSC1315 try using its transformer.
The long and short of this is there is no fuse in the printer its self. If all the above fail, in all likely hood, you have a bad printer. At the price of these printers today, replacing it will probably cost you less than the ink you purchase for it.
Jul 19, 2011 | HP PSC 1315 All-In-One InkJet Printer
Printer will not power on
Check that the corded power supply is plugged into a live receptacle. Verify by using a lamp with a light bulb to see that it lights before plugging power cord into the wall.
Check that the connection at the printer is ok.
Push the power button, and if nothing happens, you might have a bad transformer either on the cord or in the printer itself, depending on the design.
One can double check by getting a spare power supply transformer or cord and trying it.
Or else, a multimeter should show the voltage printed on the power supply or printer. Check that the voltage is within specifications when plugged into the wall whether it is AC or DC voltage.
Jul 04, 2010 | HP Office Equipment & Supplies
Driver for printer
plz check the manufacture website for driver
Aug 18, 2009 | HP DeskJet 656 Thermal Printer
HP Deskjet 9800 will not power up. Tried replacing power cord and tried plugging into a different power outlet. The little green light on the back of the power supply unit comes on, but the printer will...
Is there power coming out from the supply end
Is is a DC or and AC output supply?
If is it an AC output supply tyhebm in the back of the HP had an AC to DC converted that is realy a diode bridge and should contain a fuse in the circuit somewhere on that board
Jul 27, 2009 | HP DeskJet 9800 InkJet Printer
Need Power Supply/Cord to HP 5440 Deskjet
Hi have you tried ebay ? search,--- low voltage power supplies, check out advertising at bottom of pages.
Oct 27, 2008 | HP Deskjet 5440 InkJet Photo Printer
HP printer
Try to unplug then plug in the power cords if not working im sure your current supply will be lost. due to the current supply in your area or lost connection of your power supply.
Jun 05, 2008 | HP LaserJet 3030 All-In-One Printer
Hello
Hey daddy'o,
Try plugging it directly into the wall, instead of a surge protector. Still not coming on? You can purchase a power cord and adapter from hp.com or call hp support @ 1 800 474 6836.
Feb 13, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
HP DeskJet 656 Thermal Printer Logo
51 people viewed this question
Ekse
efs_perpends
efs_perpends
