ViewSonic VX1962wm LCD Monitor Logo
Anonymous Posted on Oct 28, 2009
Windows 7 will not allow me to pick 1680x1050 for the resolution. It defaults to a lower resolution with no option to take it higher.
A Miller
Level 3:
  • Master 8,404 Answers
  • Posted on Oct 28, 2009
A Miller
Master
Level 3:
Answers
8404
Questions
Helped
2050952
Points
24677
Go to Windows 7 web site and check the equipment compatability list for your monitor.
If it is there - read the particulars
If it is not, complain to the monitor manufacturer - ask them to create a driver for this model.
I hope this helps you
Thanks for unit FixYa.com
Positive comments welcome
a
Testimonial: "great advice and it worked. thanks."
  • A Miller Oct 29, 2009
    Thank you for the 4 thumbs up ...
    and Thanks for using FixYa.com
    a
Anonymous
Level 3:
Guru:
  • Master 830 Answers
Anonymous
Master
Level 3:
Guru:
Answers
830
Questions
Helped
210273
Points
2663
Hello and thank you for using Fixya's services.
Windows 7 (by default) installs a generic monitor and/or VGA driver. You can visit the manufacturer of the monitor (viewsonic) and download the correct driver. To obtain the VGA (video graphics card) driver, you will need to visit the computers manufacturer page (example dell.com)
Windows 7 will add these items automatically for you.
To do all updates. Go to start button. In the search bar, type in windows update. Open the windows update box and search for updates.
Windows 7 has released 35 or so drivers and updates since it's release on Oct. 22, so you can rest assured the problem will be taken care of with the updates.
Please let me know if you have any question.
Anonymous
Level 1:
Problem Solver:
  • Contributor 14 Answers
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
14
Questions
0
Helped
6871
Points
32
Download best disply driver for ur motherboard that works in windows 7. or . Go to windows updates site, select optional update, gothrugh hardware( driver) update
My desk top computer input signal out of range says change to 1680x1050-60HZ what do I DO
Just change resolution to 1680x1050. On Windows 7 right click on desktop and click screen resolution and change there...
1helpful
I cannot get good resolution in my Hannspree HF229H, what can I do???
The resolution you should be getting is 1680x1050. Under Windows 7, right click on your desktop then open 'Screen Resolution'. If the resolution is set to anything other than 1680x1050, set it to that. If that setting is not available then it is possible that your video card does not support that resolution. This would only effect old computers. If the resolution is set to 1680x1050 but you don't have the proper resolution onscreen, try adjusting the monitor settings using the buttons on the bottom of your monitor. Hope this help and have a nice day!
Hello, I have a Toshiba Dynadock U Universal USB Connect Docking Station. I have a Dell laptop with Windows 7 Professional. I set my screen resolution at 1680x1050. Whenever I turn on my laptop, the...
why dont you disable hibernation as it seems the dynadock is outputting a signal that is the maximum that your external monitor / tv is capable of showing
If i try to connect to 1680x1050, my screen goes dark. but when im using 1600x1000 it still desplays
The resolution 1680X1050 is the native resolution for your monitor. This means that the best view for your monitor is for this resolution. Your problem in not at the resolution, it's at the refresh rate. How to fix this? Go to the settings for your screen. At the lower right corner you will locate "for advanced users" button. Click on it and choose the "screen" tab. At the lower part of the window you will locate the "refresh rate". Click on it and change it at the lower setting (about 60 - 70 Hertz). Click on aplly - OK. You will be back to the resolution settings page. Set the resolution at 1680X1050, apply - ok. Go back to "refresh rate" window and change the setting to a higher setting STEP BY STEP. In case of an "out of range" and blaack screen DON'T DO ANYTHING, at 15 seconds you will come back to the previous settings. With this procedure you will get the native resolution for your screen with the higher refresh rate.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Trying to get the screen size fixed properly. screen needs to be set at 1680x1050. It is making pictures look fat
u need to check if ur monitor is capable of handling 1680x1050...resolution
go to Desktop/right click on desktop/go to properties/settings.../in the screen resolution optopn/do u c a slider than has option to select ur 1680x1050
if it has then chose that and click OK....
if ur monitor can show that resolution it will give ua msg else u wont..
mind it...a higher resolution and change regresh freq rate can spoil ur monitor....
so be careful while doing this
1helpful
Resolution problem in Windows 7
Windows 7 official release is in Oct. The Windows 7 version you have is probably the Release Candidate version, this is the last Beta version before its offical release. This version does not have drivers for al lot of devices and if you cannot get the driver from ATI at this stage then you have to wait until it becomes available.
The release Candidate will shut down every hour early next year and will stop working completely in June. You will be forced to buy Windows 7 or go back to XP or Vista.
2answers
How do I get the resolution to be the recommend 1680x1050
more powerful video card. a video card with higher resolution.
2helpful
2answers
Dell OptiPlex GX260 video drivers don't work with Windows 7
In your original question you say your max is 1280x1024 and in your second you say it is 1680x1050. The video card drivers are what determine your maximum resolution, not your operating system. If Dell has no drivers that support higher resolutions you'll have to change the video card.
2helpful
2answers
Acer x213W - setting the resolution
Sorry about the delay. I also just purchased an Acer x213w and had some trouble setting up my computer in order to achieve the optimum resolution of 1680x1050.
I'm using an HP Pavilion m7170n, so it's a bit old and thus could not support this widescreen resolution. However, my computer comes with an ATI Radeon graphics card and, upon contacting HP Support, was allowed to download ATI's "Catalyst Control Centre". After installation, these drivers added the option of selecting a screen resolution of 1680x1050 from Desktop properties.
So this is my solution to you: simply google your graphics card along with 1680x1050 driver and hopefully you'll be able to download a driver update which does the same for you as it did for me.
Top ViewSonic Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
