Question about Marantz Audio Players & Recorders
My Marantz PMD 661 digtial audio recorder is flashing ALC on the display and I can't find what that means in the book. Any idea?
Fred Yearian
  • Marantz Master
  • 5,603 Answers
ALC Automatic Level Control
In other words, an audio compressor which reduces the level when the level gets too much.
Look up "audio compression" with Google for a complete treatise how it works.
Posted on Oct 28, 2009
Testimonial: "Thanks fredy2, I haven't seen that one before and I don't know why it's telling me that, but I'll take your word for it. I appreciate your help."
Use 8 gig sd card
Yes you can simply replace 4gb card with 8gb, 16gb, ect...
the device doesn't know the difference, it just gives you more storage capacity... hope this helps?
Hi, I need the schematic diagram for marantz pdm679, Someone can help me? I am jorge, [email protected]
Jorge,
The schematic will be part of the service manual, which gives a complete explanation of dis-assembly, circuit function, parts, & adjustment. You can purchase a service manual for the Marantz PMD 670 at http://www.servicemanuals.net/ServiceManual/MARANTZ/pmd+670/pos1/results.aspx
Anthony Beeler
Spare PARTS counter for Marantz PMD 221
I am sorry but Fixya is not a parts site, we offer tech advice only.
Hi I have a marantz pmd661 with a buzz on record when set to ext mic/line with no i/p regards
If you let the input "float" with no connection it very well may buzz. The input needs to be tied down with a driving source.
PMD660 Handheld Digital Voice Recorder: I have a Marantz PMD 660 digital audio recorder. T...
This implies that there is not enough current going to the device when running on battery (only back-light but no data) whereas running fine on AC means that the device board is most likely in a good operational condition.
I think maybe once a leaked worn battery which left forgotten inside battery compartment damaged the battery terminals or at least the wires connecting these terminals to the main board, i would recommend you to open and check on that.
4helpful
Where can I get manual for Marantz PMD-221
I have manuals for the Marantz PMD 201/PMD221 and the 420/430.
Michael
Marantz PMD 660 won't power up from batteries
I would suspect the battery tray connections are defective most likely due to a broken wire.
MARANTZ PMD 101 PROBLEMS, COUNTER AND REWIND
Get the belts changed, and check a clutch inside the mech which drives the auto-stop mechanism.
It works in a way that it normally holds the auto-stop off if the spools are rotating, but when it wears, there is no srive through it to hold the auto-stop off, so the auto-stops stops, if you see what I mean.
Any good audio tech should be able to do this, if the machine otherwise works OK, it is worth doing because these are very nice and usually reliable machines.
For musical work though, the CP series are usually better, as they provide 3-heads and off-tape monitoring, with better quality and the facility to set tape bias to suit high-grade tapes.
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
