Panasonic Lumix DMC-FX8 Digital Camera Logo
Question about Panasonic Lumix DMC-FX8 Digital Camera
The lcd screen is barely visible when camera is on,i have tried changing brightness of screen in the menu but nothing happens
Posted by adonaldson94 on
1 Related Answer
Anonymous
  • 2517 Answers
SOURCE: I'm having a problem with my lumix panasonic TZ7 /
HI there can you reset the camera setting and let me know the result please.
Posted on Feb 06, 2011
I have a lg 32" tv and have connected everything
Dark picture means you have low brightness on the screen. Please increase the brightness. Also try increasing the back light intensity.
The screen on my TV is too bright barely visible
I can only make a very uneducated guess because I do not know if this is a plasma or and lcd tv or brand or model . I've
2helpful
It has a very dark screen, I can barely see my
Check the pins on both end of the connector, make sure they're straight other wise, reposition it with fine long nose pliers. Make sure the connectors are push and screwed tight also. Let us know!
2helpful
Black Screen
Did you leave it in the sun . Or in a hot place ? Was it wet in any way ?
I can't see digital display on the screen
Have you tried to adjust the monitor brightness? There is a function in the menu for Monitor Brightness that will allow you to make the LCD display lighter or darker. Go to Mode Menu and then down to Setup tab and then to the icon for Monitor Brightness (page 88 of the advanced user manual explains how to set this up).
Camera monitor very light
The LCD Monitor Brightness has a range of -5 to +5.
Rotate the mode dial to Setup. Turn on your camera.
Go into the Setup Menu, then Custom, then select LCD Brightness. Make adjustments as needed.
Let me know if this fixes the LCD monitor. Thank you, Binary Bob
Fuji f20. Led screen dark. Pictures and menus barely visible.
there may be a portion of the menu -> setup that lets you set the brightness of the lcd. i know i can do it on my s5100 so you may be able to do so as well.
Oct 13, 2008 • Cameras
2answers
LCD Display Blank
I have a sony cybershot DSC-S650, the LCD was very dark and could not see anything except if I pointed it at a bright object, everything else worked ok. I could take pictures but could barely see them in playback as well.
I took it to Sony authorised repair outlet and was told the CCD was damaged, they charged me USD $55 to repair it (in Quito, Ecuador)
1helpful
2answers
Dark screen
Please check your user manual. There is an save mode. Leaving the save mode will solve the problem. If you need more help please advice.
LCD screen
I tried a hood from the HOODMAN and it was better than nothing but the best solution comes from http:\www.photosolve.com. They have a very reasonably priced metal hood that attaches with velcro. In addition it gives 2X magnification which is great for focusing macros, etc. I use mine with the Eagle Eye 5X lens and I get some really sharp shots because I can focus accurately. Try it. You'll like it.
Top Panasonic Cameras Experts
Narseman
rhodesworks
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
