Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
Posted on Oct 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My washer is leaking water near the water tube located right in front of the washer. Do I need to replace something or can I seal it?
Anonymous
Level 2:
  • Expert 90 Answers
  • Posted on Oct 27, 2009
Anonymous
Expert
Level 2:
Answers
90
Questions
Helped
21985
Points
262
Most likely u will need to replace part.u should remove the cabinet to get a better look at where the leak is . the cabinet comes off from the front.
1helpful
Leak in front
It leaks Your washer can develop several types of leaks. You can track down a leak based on when it occurs: During fill only During drain and spin only All the time During fill only If the washer leaks only during the fill cycle, check these: Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it. The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak. Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak. During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details. All the time If the washer leaks all the time, check these: Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate. Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician. Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it. Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details
1helpful
WATER LEAKING FROM THE WASHER
It leaks Your washer can develop several types of leaks. You can track down a leak based on when it occurs: During fill only During drain and spin only All the time During fill only If the washer leaks only during the fill cycle, check these: Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it. The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak. Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak. During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details. All the time If the washer leaks all the time, check these: Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate. Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician. Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it. Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make, check glass seal too!
4helpful
Bosch washing machine leaks at right bottom
The part that you removed, was the pump filter, the pump is located behind the filter, possibly, the pump itself is leaking, or the filter cover is not fastened in tight enough, pr the filter seal is defective, if after tightening, it still leaks, suggest you replace the pump.
Please rate my solution.
Thanks.
5helpful
Only leaks from front bottom when filling
During fill only
All the time
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Water leak in washing machine
During fill only
All the time
2helpful
Amana washer model LW6501W2 leaks in front during fill up
During fill only
All the time
1helpful
Water leaking from bottom of front lode washing machine
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
All the time
During fill only
All the time
4helpful
My front loader is leaking water from the bottom
During fill only
All the time
During fill only
All the time
2answers
Leaking door due to the wire ring that holds rubber seal
Bosch Nexxt 500 WFMC3301 Front Load Washer how
to get the metal ring back on.
This video will show you how to change a door seal on this Bosch front loader washing machine and also how to replace the metal rings.
we have all bosch repairs in our channel.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
2helpful
3answers
He2 leaking from detergent dispensor
Plug off the wall, etc. Remove the rear cover. There is a thin tube coming from the control panel area to the base where the water exits, this should not be blocked, remove from top and blow to check, refit. Next clean out your outlet filter, it could be clogged, refit. This tube controls the water level. Another thing that could be the problem: Try to take the top of the machine off; there are three tubes coming into the dispenser box, these may hv come loose or something. Connect well.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
