Question about Stanley Hand Tools
Stanley 10-777 utility knife: I need to reinsert the retractable blade slide back into the knife body. I try but the knife won't close.
Posted by aquilter2 on
  • Leroy Elliott
    Leroy Elliott May 11, 2010
    I don't think you should be playing with sharp objects in your delicate condition.
C Lawrence
    New Friend:
I had the same trouble. The blade holder was out of the knife and would not go back in. I fixed it this way: open the screw knob all the way to the least tension. Slide the two parts open but not all the way- there is a tab on the blade holder that gets in the way if you try to drop it in at the fully open position. With the two halves SLIGHTLY open- slide the blade holder in making sure that the tab is seated in it's slot. Depress the thumb tab and bring it to the most forward position and the two halves should be able to be seated together again.
Posted on Dec 12, 2013
Jim Parker
  • 1,041 Answers
Make sure the blade lays flat into the blade cradle. And the cradle also must lay just right within the knife.
Jim
Posted on Nov 27, 2009
  • Jim Parker
    Jim Parker Dec 01, 2009
    Did this solve the problem?
    Jim
Can't close stanley fatmax
It only goes in one way, try to loosen the screw a little
Jul 30, 2012 | Stanley Fatmax Xtreme Retractable Utility...
How to open stanley fatmax knife 10-778 TO CHANGE THE BLADE. thank you
How do I change the blade on the quick change/instant change knife? Warning: Blades are sharp and can cause serious injury. Be extremely careful when handling blades. Wear eye protection and dispose of used blades properly, such as wrapping in duct tape.
FULLY EXTEND THE BLADE.
Press down and forward again on the slide button until the button is in the full front of the top slot (0 through 3 in the below picture).
Note- the blade must be extended beyond the 3rd detent position. This will cause the slide button to remain in a down position, allowing the blade release button to operate.
PRESS AND HOLD THE BLADE RELEASE BUTTON ON THE FRONT SIDE OF THE KNIFE. (Step 4 in the below picture)
Note- if the blade is not fully extended beyond position 3) , the blade release button will not work.
Remove the old blade carefully.
Insert new blade.
NOW, RELEASE THE BLADE RELEASE BUTTON.
ENSURE THE BLADE IS LOCKED IN PLACE. If the blade does not retract, try carefully giving a slight tug on the blade to reseat.
Jul 13, 2011 | Stanley Fatmax Xtreme Retractable Utility...
I cannot figure out how to put a blade in my Stanley FatMax fixed blade utility knife. There are no instructions with the knife.
at the handel end it will pull apartthen slide the whats left of the old blade and put new won in its place just do it slowly so you dont forget how it goes
Apr 21, 2011 | Stanley Utility Knife
Can i buy a new blade slide for extreme utility knife
I can't see what country you live in from your profile, but if it's the UK, you could try www.partmaster.co.uk . They sell parts for just about anything.
Feb 28, 2011 | Stanley Fatmax Xtreme Retractable Utility...
Describe how you put a blade in FatMax model 10-778
The model in your picture is a fixed blade utility knife (model 10-816). Your question asks for instructions for model 10-778, which is a retractable knife. I'll guide you through the 10-778 which you asked for, if you need instructions for the pictured 10-816 please re-post the question.
Push the thumb slide forward as far as it goes exposing the blade. Press the blade change button on the side of the knife (the small button on the left side near the blade) and pull out the old blade.
Insert the new blade and slide thumb slide back to fully engage blade in the internal lock.
Dec 26, 2010 | Stanley Fatmax Xtreme Retractable Utility...
Cant put the thing back together after putting in new blade !!!fat max knife
some stanley knifes require stanley blades only, or make sure the clip blade is in is seated in the grove completely.
Dec 23, 2010 | Stanley Fatmax Xtreme Retractable Utility...
Stanley 10-801 utility knife. How do you change the replaceble blade?
On the pivot end of the bladed knife is a black plug that says pull. They actually mean "Push". push it away from the knife body and rotate the handle half it's mounted in, down. The body will rotate in half , revealing the utility blade and more blades in the rear storage.Also note the blade depth adjustment has a locking detent. You have to push it to the right to unlock the utility blade.and push it to the right when retracting to fully retract and lock the utility blade.
Nov 26, 2010 | Stanley Garden
Just purchased a Stanley FatMax 10-778 retractable knife. Cannot figure out how to load the blade for use.
1. Make sure the side lock is unlocked.
2. Push the thumb tab all the way to the front of the blade handle.
3. Insert the blade in the opening, you may notice two notches on the top side of the blade.
4. Press the small blade release button as you slide the blade into the knife. You may have to jiggle up and down to get the two notches on the blade fully into the handle.
If properly inserted, the exposed area of the blade should look very close to an equilateral triangle.
make sure both notches of the blade are inside the handle. They notch into the thumb lever.
good luck
Mar 20, 2010 | Stanley Fatmax Xtreme Retractable Utility...
I brought a stanley fatmax retractable knife, have no idea why the blade is not coming out, trying to figure out if i did something wrong like putting the blade in the wrong spot.. this is the only time...
Are you using Stanley Blades or off brand? Hey, I use off brand but sometimes it does make a difference. Second, make sure the blade slider is clean. If you were cutting shingles, for instance, the tar gets in there and screws things up.. try WD-40 spray it liberally all over the blade slide and buttons. If that doesn't work and you purchased it at a Menards store, I can speak of experience they'll replace it no hassle.
I hope I helped
Jan 09, 2018 | Stanley Fatmax Xtreme Retractable Utility...
Stanley 10-788 how to change blade
Push the top metal button all the way foward as if pushing the blade out to it's (farthest) 3rd setting. Then push foward and down one more time which locks the mechanism down. Push and hold the yellow side button as you insert the blade. When the blade locks in all you have to do is release the yellow button and return the top slide to it is fully retracted home. The blade is loaded
Jan 14, 2010 | Hand Tools
Hand Tools Logo
749 people viewed this question
Top Stanley Hand Tools Experts
Marvin
Marvin
efs_perpends
efs_perpends
Bill Boyd
Are you a Stanley Hand Tool Expert? Answer questions, earn points and help others
