Question about Xerox DocuColor 12 Printer
When it jams it says 10-105 at the bottom left of
I have a xerox docu 12 when it jams it says 10-105 at the bottom left of the screen
Posted by thinkink434 on
docukaaf
    Habit-Forming:
  • 38 Answers
This problem is common when heavyweight paper is fed from the tray long edge first. and then the fuser exit sensor did not actuate within the specified time. Clean the drawer from dust or oil. if this not solve the problem change the fuser exit sensor
Posted on Oct 31, 2009
I have xerox dc 250 machine, it shows fault code 077-909, paper jam at tranfer module but i checked there is no paper in it??
Hello friend, you are not alone !!!!
From http://www.copytechnet.com/forums/xerox/28764-dc-250-fuser-problem-077-909-a.html
At the bottom of the page it says.......
'what sometimes happens is that the sensor flag/arm call it what you will, twists out of its holder and jams, hence the machine thinks that there is still paper. the flag/arm should pivot freely'
Sep 03, 2014 | upbright AC / DC Adapter For XEROX...
Printer quality poor after labels get jammed. Xerox Docu Color 240
Just remove the cartridges from the printer the clean inside the printer and print.
Aug 27, 2012 | Xerox DocuColor 240 All-In-One Laser...
Code erreur 9-363 de la DOCU-COLOUR 12 XEROX
  • 9-363 is Rotary home position (rotory controler board fuse) first remove the right side cover to see devloper units top side sensor clean or replace and chek all fuses on back side pwr board.
Thankyou
Mahesh
[email protected]
Jan 20, 2011 | Xerox DocuColor 12 Color Copier
Is that possible to print 12.6" X 19.2" in Docu Color 12 . Please tell me in detail
My spec book says max is 12.6" x 17.7"
with an effective print area of 11.7" x 17.2"
Jul 26, 2010 | Xerox DocuColor 12 Printer
Xerox dc-12 system fault - Error code 10-389
that could be your fuser/youll maybe have to reset an nwm
Aug 30, 2009 | Xerox DocuColor 12 Printer
Error 9-378
hi ur drum life is expired.. now u wand replace ur drum.
Jan 19, 2009 | Xerox DocuColor 12 Printer
Dc12 copier print is some times darker and lighter
i dont understad you problem all rigth, but maybe you need a calibration, see when was the last time
Nov 25, 2008 | Xerox DocuColor 12 Printer
Command Workstation for fiery x15
xerox.com look for dc 3535 in support and drivers and the new command workstation is in there
Oct 27, 2008 | Xerox DocuColor 12 Printer
Xerox DocuColor 12 Printer Logo
339 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
