Question about JVC Everio GZ-MG155 Camcorder
I zoom in and out on a subject the subject gets jvc gz-mg142ek
I zoom in and out on a subject the subject gets blurred and cannot be seen on screen. This has happened today after a successful 20 months successful recording. What could be wrong?
Posted by denishanlon on
Anonymous
    New Friend:
The gears or machinery thet move the inside lenses are broken or out of place. I've just opened mine to try to find the exact problem. good luck.
Posted on Nov 29, 2009
Fujifil FinePix S6500fd: How to focus the subject(blur the background)? Like this: http://sphotos.ak.fbcdn.net/hphotos-ak-ash2/hs604.ash2/155662_1475615262462_1596139557_31044751_765416_n.jpg
What you are asking about is called depth of field. Boiled down, it means that there is a certain amount of area in an image that is in focus, given the focal length of the lens, the aperture (size of the shutter opening) and some other factors. There's a lot of theory behind it, but you just want to know how to accomplish that creative blur behind the subject, right?
If your camera has the capability to choose the aperture, known as the f-stop, either with a manual mode or an aperture-priority mode, then this is pretty easy. The larger the aperture (size of shutter opening) the smaller the depth of field, which means only a small area is in focus. The aperture, or f-stop, is denoted with numbers like F/2.8 or F/8, etc. The lower the number, the bigger the aperture and the more background blur you will get. There is an inverse relation ship between shutter opening and speed, too. A big opening like F2.8 means a faster shutter speed, versus a small opening like F/22. Every lens is different, so your aperture options will vary.
If your camera does not allow you to choose the aperture, it may still have a "scene" setting you can use. A "portrait" or "night" setting usually has a bigger aperture than, say, a "landscape" setting.
Other factors also contribute to creating background blur. All else being equal, the blur increases as you move closer to the subject or as you zoom in on the subject with a zoom lens. Also, having greater space between the background and your subject increases blur.
So, to maximize background blur and create a shallow depth of field, you want to pick the largest aperture possible (smallest f-stop number), you want to get close to the subject and extend your zoom as much as you can, and you want to maximize the distance between the subject and the start of any background objects. Your success will depend in part on your camera and lenses.
If all else fails, you can also artificially create the background blur in software after the image is taken, but that's another story!
Dec 16, 2010 | Fuji Cameras
I have a JVC GZ-HD300 Hard disc video camera and when using Everio Mediabrowser which comes with the camera download to convert my videos the conversion leaves the finished video blurred
Hi.
If the original footage was sharp, that means that you are probably using wrong compression parameter or format on Everio, while doing conversion.
If the source movie was blurred instead, try using the Advanced Image Stabilisation option, usually available in new JVC HD camcorder menu.
Everio has different quality settings. Each time you increase compression you lower quality.
Also ensure that the camera was not in a low definition setting.
Regards.
Ginko.
In addition
Jun 12, 2010 | Cameras
Gz-mg335hek video cmera goes blurred when
go through ur menu and put the zoom/focus on manual, it sounds like its on auto.
Jul 22, 2009 | JVC Video Cameras
JVC Enverio GZ-MG155 30gb camcorder
Try removing the battery and see if it changes back to the default settings.
Aug 04, 2008 | JVC Everio GZ-MG130 Camcorder
I need software for my apple to enable me to use my JVC GZ-MG142EK and make dvds
Jul 19, 2008 | Cameras
Blurred video
send ur camcorder to the nearest JVC service centre,maybe the lens need to change.They will do 'adjustment' for u..maybe..
Mar 13, 2008 | JVC Everio GZ-MG21 Camcorder
I have recently bought a JVC GZ-MG142EK camcorder and I have a problem with a blue dot, which also shows up during playback on a PC or TV screen. Please can you advise how to remove this dot.
You cant in a word
This seems to me to be a CCD fault.
Unless I misunderstand you and the blue dot signifies an action you should take- or is a 'Recording' signal although these are usually red.=Check the manual re this
I suggest you contact the makers support website prior to returning to vendor.
Feb 03, 2008 | Cameras
JVC Everio GZ-MG155 Camcorder Logo
219 people viewed this question
Top JVC Video Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Larry Stiles
Larry Stiles
Al Rush
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
