Maxtor One-touch  III Mini 40 GB USB 2.0 Hard Drive Logo
Posted on Oct 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Computer is not detecting my maxtor onetouch III
Neither my laptop nor desktop computer are not detecting my maxtor onetouch III external drive any more. is the information salvageable?
George Marian Pascale
Level 2:
  • Expert 225 Answers
  • Posted on Oct 28, 2009
Expert
Level 2:
Answers
225
Questions
0
Helped
63875
Points
751
The hard disk interface could be broken, open the hard disk case and use it as an internal hard disk as a slave in a computer to save your data
My pc and laptop not detect my Maxtor OneTouch III Mini External 100GB USB 2.0 Hard Drive R01E100 what can i do please help me soon as possible
Good Day Anantsharma8!
If your PC and Laptop can not detect your external hard drive, I do suggest you check its usb cable. A substitute cable will confirm if your current usb cable is faulty or has an open wire.
Most common reason why the external hard drive is not recognize by PC or Laptop is due to loose connection of the hard disk inside the connectors of the enclosure.
Anantsharma8, if you have a small precision screw, I recommend you open the enclosure of the external hard drive. Remove the front face where usb and power plug connects, then slide it out to expose the hard disk also. You will see two connectors. These are the ones that always loosen. Please disconnect both the connectors and then connect it again properly. Put the hard disk back, close the enclosure and try to connect again with your PC or laptop via usb cable.
Good Luck! I hope that it will soon recognize your external hard drive.
My pc cannot detect my maxtor one touch external hard disk
Please try connecting it to another computer. That way we'll know if the problem is with the computer or with the actual device itself ;) Let us know what happens or doesn't happen :(
Other computers dont recognize my Maxtor OneTouch 4 Mini
Please Make sure you External Hard disk USB cable is working correctly. Your cable is probably having partial contact, so try another cable
2answers
Open up the case
Well, since you are discarding the case, use a small flat head screw driver or something to pry the case open. Once inside, the HD will be plugged in to a circuit board and screwed in place. Unscrew it and carefuly unplug the HD from the circuit board. Then you can transfer it to another external HD housing.
Maxtor OneTouch III Not Recognized by XP
sounds like the USb Port is burned out, might as well chuck it
Top Maxtor Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
