2002 Jeep Wrangler Logo
Anonymous Posted on Oct 27, 2009
2002 Wrangler Sport Blowing COLD air.
2002 Wrangler Sport 152K never had an issue until now. It's been chilly lately here in NY and I've been starting to use the heat...Well I started up the car, let it warm up (it's fully warmed when it reached 210 on the thermostat/temp gauge) and I turned the heat on to floor/vent. Cold Air. I turned it off, back on same thing. Slowly checked each setting, they all work but continues to blow cold air. So i left it on low and put the car in drive and proceeded to work..about half way down my driveway it then gets hot air. I thought maybe a one time thing...well I was wrong.. it did the same thing every time I start her up now. Sometimes it's a pain because it'll stay on cold and not go to hot. She's never done this since I drove her off the lot new.
Any ideas?
  • Anonymous Oct 27, 2009
    Coolant was changed at 145K (about 6 months ago)...the problem has been since 2 months ago aprox.
Anonymous
Level 1:
Problem Solver:
  • Contributor 17 Answers
  • Posted on Oct 27, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
17
Questions
0
Helped
8518
Points
38
Have you recently changed / or added coolants? your Coolant system may need to bleed.
Heater on jeep wrangler sport I have no heat and the lever only blows on high we have snow and frost here in NY my daughter freezes in morning help me please
There are two issues here.
If there is no heat or not hot enough, replace the thermostat and Check the coolant level.
No Air coming out could be either the Blower Motor, The Blower Motor Resistor pack or the switch in the dash. These jeeps are know to burn up the switch and wiring harness when the motor draws too many amps. I just installed all of the above in my 2000 4.0 Sport.
1helpful
A/c blowing hot air with low pressure
The first thing to do would be go to your local auto parts store and buy an air conditioning recharge kit. Provided your vehicle isn't too old, they sell recharge kits that require no tools.
If their is a leak anywhere while you recharge, you will know.
Try recharging the air conditioning first, it is very simple and the kits come with simple instructions.
If there are no leaks, your A\C will blow cold air again. As for the pressure, if it continues to slightly blow air you may be looking at a new air compressor unit or a vaccum line. A new unit will run you anywhere from $200-$2000 dollars plus labor depending on the vehicle.
If the recharge works, at least you will have slightly blowing cold air rather than hot and you can continue that way until the unit fails.
Warm air blowing from A/C
you need to install gauges and check ac pressures. if pressures are equalized then you have a bad compressor. a simple test is to make sure compressor is running and check to see if the drier is cold, it should be very cold and sweating.
2answers
1997 jeep wrangler heater blowing cold airWhat's your problem?
Heater blowing cold air,indicates towards low or no coolant or the coolant flow is getting obstructed or the heater core is clogged or hot to cold moving flap/ door is stuck in cold mode. There are many possibilities, that needs to be checked. Click the link below for step by step details:--- http://technoanswers.blogspot.com/2011/10/heater-blows-only-cold-air.html ---------- This should help.Thanks.Helpmech.
10helpful
2answers
Heater not working it is blowing cold air at all times is there a
Heater blowing cold air until I get on the interstate, then it works; however, when I stop at lights it starts blowing cold air again. The temperature gauge will be in the middle but the car will still be cold until the car starts moving.
I am changing the oil in the manual transmission of my 2002 jeep wrangler sport. i have drained it and am trying to put the fluid in. the manual calls for 3.5 qts. i can't get 2 in without it pouring out...
Let it sit for awhile because it takes cold oil a while to leak down to fill everything. Did you get 3.5 quarts of oil out when you drained? Just add as much as you can, wait awhile, check your dipstick, and add more until you can get it all in the fill hole. With a cold engine and cold oil, it takes a little while.
1helpful
2answers
Why can i only fit 13 gallons in my 19 gallon gas tank on my 2002 jeep wrangler sport 4.0
You can usually only get about 18 gallons in a 19 gallon tank and you likely have 4 gallons left in it when the gauge reads empty
Jeep Wrangler 03 A/C stopped working abruptly
This may be the AC compressor cycling switch is defective. It is located in the larger of the 2 AC lines coming from the compressor, it has a wire connector to it with 2-3 wires. To verify this is the issue jumper the connector with a small piece of wire and see if the compressor runs.
Top Jeep Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Jeep Expert? Answer questions, earn points and help others
