No you can't. The turntable needs to rotate the food or the microwave energy will burn holes in your food. The rotation spreads the heat evenly throughout the food. You can test it by removing the turntable and put a plate on the base with a pound of butter on it. Microwave on full power for a minute. Notice the holes?
what problem do you have mention ? attached is there a list please indicate. God bless you
No Lights or Power, Unit seems Dead The voltage to the unit is good.Lights come on, but can not program unit, Touchpad dead Microwave Runs, but no Heat Turntable rotates, acts like it is heating but doesn't. This is the big one, many possibilities. Microwave Runs, Heats, but turntable does not move Microwave is arcing Microwave Vent Hood is not working Over The Range(OTR) Models. Microwave Stove Light not Working OTR models, light bulbs good. Microwave overheats and keeps turning off
see this tips for to repair: Inspect
the plastic drive coupling that the tray sits on, as well as the
ring-and-roller assembly, to make sure that they're working properly. First, make sure the turntable coupler under the glass
dish is not broken. Second, on the control board, find the turntable
relay and test for voltage. Some turntable motors are 24 volts DC, so
make sure your testing the correct voltage. If no voltage from the
control board, then replace the control board. Otherwise head towards
the turntable motor.On OTR models, you can get to the motor by
un-screwing the bottom panel on the microwave. On countertop models,
there will either be a knockout or screw on access panel. Check for
voltage at the motor. If no voltage, check the wiring back towards the
control. If voltage, then replace the turntable motor. The component
list below also shows how to test a turntable motor.
The turntable system typically consists of the motor, the coupler, the turntable support with rollers, and the tray.
Here is a video of how a turntable motor should sound when you rotate it by hand.
If
yours is not set to be off via the control panel, and it won't rotate
or it sounds like it's grinding, etc., you may have a bad motor or
plastic coupler.
To
replace either, you need to unplug power, then remove the bottom cover
of the oven.
You can find
links to helpful exploded view diagrams and part ordering help here.
But if you've recently had trouble with the cooktop lights, then the control board may be damaged.
We
regularly repair these control units for customers nationwide by
mail for $39.95 postpaid in about a week or so with a one-year
guarantee.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
We have a similar problem! It sounds like a problem with the microswitch inside the unit that the door is suppose to engage when closed. If not engaged properly, it will not cook. We had the switch replaced last March but it has started acting up again. We can press in on the door and/or lift it slightly and it will cook. Try putting time on the counter and hit start. It the word "cook" appears then try moving the door slightly and see if the turntable starts turning. If not, then you may have a more serious problem. Good luck!
If the turntable does rotate, I'd suspect a more significant failure, such as the transformer, capacitor, or magnetron. If it's any of these, it's time to replace the unit.
