Question about OEM Systems Computers & Internet
I'm running an Nvidia FX 3500 PCI 256 vram on a Gigabyte Mobo with an ATI video chip set. The computer came with an ATI card and i replaced it with an OEM. It was fine, recently I experienced matrixed dashes in rows anc columns as well as triangluated windows in the Vista OS. Problems stopped when I re installed the ATI card.
Posted by alepage on
5 Related Answers
Anonymous
  • 17 Answers
SOURCE: D530 sff Vidio Card
what wattage power supply do you have? and did you install the video software from the disk, or did you download it from the manufacturers' websites? (I recommend the latter)
Posted on Aug 28, 2008
Zulfir
Zulfir Sadat
  • 73 Answers
SOURCE: "Call of Duty" runs in slow motion on my PC.
Yes Thomas, You can install a video card such as nvidia 9000 series.... That will definiely increase the performance of the computer.
Posted on Mar 20, 2009
Anonymous
  • 27 Answers
SOURCE: Inexpensive computer for video rendering. (laptops have a non removable GPU chip so...)
Definetly the ati one. 120 stream processors is really good and it has
direct x10.
Posted on May 27, 2009
Anonymous
  • 126 Answers
SOURCE: Intel D945GCZ, PCI-E video card
Mostly PCI-E now are good vga card, i have a tip for you... there's is a secret between a 512MB & 1GB PCI-E card. With this feature is required a good power supply, like for example I used Power Supply 550watts (original 500watts power supply). This power supply is different from 350watts and 500watts.. Here is a secret buy a 550 watts to boost PCI-E card both 512MB & 1GB. Secretly this performance are based on my own analysis using CPU booster freeware... I'm sure 100% more compatible & perfectly to your motherboard. Just try it at least you have idea where you want to grab PCI-E cards (any Model).
Posted on Dec 26, 2009
STEVEN SEATON
  • 525 Answers
SOURCE: NVIDIA Quadro FX550 FX 550
you should upgrade your power supply.
Posted on Mar 21, 2011
Will fifa 11 work on ati hd 4750??
Minimum System Requirements for Fifa 11: Operating System : Microsoft Windows XP / Windows Vista / Windows 7
Processor : Intel Core 2 Duo at 1.8 GHz / Athlon 64 X2 Dual Core 5400+
Video Card : 256 MB VRAM - (NVIDIA GeForce 6800 or better / ATI Radeon X1600 or better) **
Memory : 1 GB RAM (2 GB required for Windows Vista / Windows 7)
Hard Disk : 6.5 GB of free Hard Drive space
Sound Card: DirectX 9.0c Compatible
Direct X : 9.0c
Controls : Keyboard & Mouse
Installation : DVD-ROM Drive
**Supported Chipsets :
NVIDIA GeForce® 6xxx series (6800 or greater)
NVIDIA GeForce® 7xxx series
NVIDIA GeForce® 8xxx series
NVIDIA GeForce® 9xxx series
NVIDIA GeForce® GTX 2xx series
ATI Radeonâ„¢ X1600 (X1600 or greater)
ATI Radeonâ„¢ X1800
ATI Radeonâ„¢ X1900
ATI Radeonâ„¢ X1950
ATI Radeonâ„¢ HD 2xxx series
ATI Radeonâ„¢ HD 3xxx series
ATI Radeonâ„¢ HD 4xxx series
Yes, it will work on an ATI HD4750.
Please rate this solution by clicking the thumbs up at the top right of this solution. Your rating is much appreciated.
Thanks.
Nov 02, 2010 | EA Sports Video Game Consoles & Games
Is ATI Rage XL 8MB PCI VGA 3D Video Card
Good day sir, Yes, its a standard PCI card that can be placed on any PCI slot on the motherboard.
Nov 05, 2009 | Gigabyte GA-7ZXE Motherboard
No screen
HI I'm mhel , try to replace your memory card (RAM) with a new one this should do the trick.
e-mail me if this help
mhel
[email protected]
[email protected]
May 31, 2009 | Gigabyte GA-7N400 Pro 2 : ATX Socket A...
ATI verces Nvidia
nVidia is the better choice.
Apr 11, 2009 | Dell Dimension 3100 PC Desktop
direct x10.
Jan 08, 2009 | HP Pavilion dv6000z Notebook
Video card
The MSI KT4V motherboard is an AGP board supporting 4x/8x AGP. You cannot use a newer PCI-Express Video Card, however an Nvidia GeForce FX 5500 either PCI or AGP will run just fine in it. The NVidia FX 5500 doesn't come in PCI-E. Additionally The ATI Radeon 9550 doesn't come PCI-E so you should be safe with AGP versions of either. I should note however, that you'll get better performance out of the ATI Radeon 9550 as opposed to the NVidia FX 5500.
I hope this answers your question,
Analog Anomaly
Dec 18, 2008 | MSI KT4V (MS-6712) Motherboard
EA Game ''Spore'' - Videocard & Driver Issue
Well, I can solve it but it is somewhat bad news. Basically your video card is not powerful enough. Here are the ATI specs from the EA website;
  • ATI Radeon™ series
  • 9500, 9600, 9800
  • X300, X600, X700, X800, X850
  • X1300, X1600, X1800, X1900, X1950
  • 2400, 2600, 2900
  • 3450, 3650, 3850, 3870,
  • 4850
    and here are NVIDIA
  • NVIDIA GeForce series
  • FX 5900, FX 5950
  • 6200, 6500, 6600, 6800,
  • 7200, 7300, 7600, 7800, 7900, 7950
  • 8400, 8500, 8600, 8800
  • 9600, 9800, GTX 260, GTX 280
    I would recommend buying a new video card. You can pick up a NVIDIA 8400 thru 8600 for about $30 or $40 from Frys.com or newegg.com sometimes cheaper with rebate.
    They are fairly easy to install.
    Good Luck.
    Dec 14, 2008 | ATI RADEON 9250 256MB PCI (Retail) Graphic...
    Graphics card for ACER ASPIRE 7720G laptop.
    This is from Acer's US SUpport Site:
    Video Subsystem
    ATI Mobility Radeon™ HD 2300 with up to 896 MB of HyperMemory™ (128 MB of dedicated GDDR2 VRAM, up to 768 MB of shared system memory), supporting Microsoft® DirectX® 9 and PCI Express®
    or:
    ATI Mobility Radeon™ HD 2300 with up to 1 GB of HyperMemory™ (256 MB of dedicated GDDR2 VRAM, up to 768 MB of shared system memory), supporting Microsoft® DirectX® 9 and PCI Express®
    (varies by model)
    http://www.acerpanam.com/synapse/forms/portal20.cfm?recordid=561&formid=3404&website=AcerPanAm.com/us&siteid=7293&words=all&keywords=&areaid=7
    Oct 14, 2008 | Acer Aspire 5500 5570-2609 Laptop
    Can i upgrade my fx 5500
    ya u can pci right so u want best buiggest pci card u can get wich aint much more fx 5700 i think fastest they make pull it out put new one in
    Jan 27, 2008 | Palit Microsystems GeForce FX5500, (256...
    No any video signal from the video card
    When you power on your computer do you hear any system beeps from the PC speaker? When the computer is turned on it will run through a system check and one of the things it checks for is the presence of a working video card. One beep typically means everything checked out ok and your graphics card is working and it will continue to boot. If you are getting past that initial test I would next look at the monitor and see if it can handle the signal that is being sent to it. Are you not getting any of the boot up text display?
    May 31, 2007 | Gigabyte ATI RADEON X550 , (256 MB) PCI...
    Computers & Internet Logo
    76 people viewed this question
    Top OEM Systems Computers & Internet Experts
    Bill Boyd
    Watching Him
    Watching Him
    Dayton Computer
    Dayton Computer
    Are you an OEM Systems Computer and Internet Expert? Answer questions, earn points and help others
