Question about Zenith VR4207HF VHS VCR
Are there problems recording to a vcr when using a digital converter box?
Posted by kcairns on
Bill Jones
    Habit-Forming:
    New Friend:
  • 66 Answers
Not at all, as long as the channel selector on the back of the VCR is set to channel 3 to receive the signal and record. Connect the digital convertor box to the VCR. Connect a second co-ax cable to the TV to complete the signal loop. Tune your TV on the channel you want to watch/record. Put the VCR on channel three on the display screen. Try recording and play it back. This will ensure all your connections are correct. Hope this helps, if not let me know.
Posted on Oct 27, 2009
Have digital TV have 3 yr old sony VHS VCR DVD player combo
A DTV converter box will take digital broadcast signals from the antenna and convert them to a format compatible with the VCR. You will be able to record programs received through the DTV box on your VCR if you could record analog over-the-air programs before the digital changeover. You can use either the RF output or the component output from the DTV box to input to the VCR.
Jun 30, 2009 | Quasar VHQ400 VHS VCR
I have a new digital tv but can't get my vcr/dvd player recorder to work. Can I use the converter box on a digital tv? will it work to record and play.
The output connection from the VCR/DVD needs to be different for the new digital TV. Instead of using the RF output from the VCR, use the video and audio outputs and connect them to the video and audio inputs on the digital TV. When you want to watch the VCR, select "video in" on the TV. The digital converter box should be hooked to the input of the VCR so you can record programs off-air.
Jun 14, 2009 | Insignia Digital-to-Analog Converter for...
Ambiuous Information out there
I kind of think the people that wrote the manuals didn't bother hooking up a unit. Here is some help.
The converter box is nothing more then a tv tuner that picks up a digital signal and converts it into analog so your tv can view it.
The vcr, to record programs has to be set to channel 3 or 4 (whatever the converter box is broadcasting on) to record. The converter for the vcr will have to set to whatever channel you want to record from every time you use the vcr and left on as this is the only was the vcr can pick up a signal. Make sure the power saver on the converter box is set to off.
If your tv converter box has digital pass through, all you have to do is turn the tv converter box off and it your tv should pick up the singal from your vcr when you play tapes. You also use this method to access the menu on the vcr.
Jun 04, 2009 | Insignia Digital-to-Analog Converter for...
Sound problems with recording to vcr using converter box
If your TV has no scart connection, no HDMI connection, then to be honest I would get a new set. There are plenty of good second hand models around, which will be better than your old set and come with a digital tuner built in.
As for the VCR, that should have a scart socket and so should the converter box. Once connected via the scart socket you should be be able to record the shows easily. If the converter box comes with a volume control, you might need to set that up to get it right. If the VCR has two scart sockets use the second one to connect the box. Use the first to connect to the TV for viewing your recordings only.
If it has only one scart, then look around on Amazon for one of these scart switching boxers.
Mar 19, 2017 | Insignia Digital-to-Analog Converter for...
Vcr hooked to tv and converter box. Will not record digital chann
The vcr has to be set to channel 3 or 4. The converter box has to set to the channel you want to record the show from and left on during the time that the vcr is recording or you will get no recordings.
Apr 19, 2009 | Philips Magnavox DVD/VCR Dual Player
Quazar Model VHQ520/VHQ540 cannot record after inst Digital Conv
You need to set the vcr to channel 3 or 4 (whatever channel the digital converter box is set to broadcast on) to record a program. The digital converter box has to be set to the channel you want to record the show from.
Apr 09, 2009 | Quasar VHQ400 VHS VCR
Timer record on vcr/dvd attached to digital convtr box
You have to set the vcr to channel 3 or 4 (whatever the converter box is set to broadcast on). The signal to record has to come through the converter box. Since the VCR only has a analog tuner, it cannot pick up any digital channels on it's own.
Mar 29, 2009 | Sansui VRDVD5000 DVD Recorder/VCR
Want to continue to record on my VCR after digital hookup
You have to use the RCA plugs on the back of the converter box and the tv (red,yellow and white). Or you can attach the antenna wire to box and then attach the wire that comes with the converter that is listed as to the tv and instead attach it to the antenna in on the vcr. The converter box will determine which channel your vcr will get a singal to record from. Your VCR for every program will be set to channel 3 or 4 (depending on what your converter box is set to broadcast on). Make sure the power saver on the converter box is turned off as if you want to record a program in say 4 hours, if the converter box turns off in 2, your vcr will have nothing to record.
I ran seperate coaxible cable to the tv from vcr and unplug the tv converter box everytime I want to watch the vcr. You can also use the RCA cord to send the signal from the vcr to the tv and use the input signal to watch your recorded programs. I had static showing up everytime I played it through the second converter box thus I solved it by running a seperate coax line. I don't know if you will have this problem, just wanted you to be aware.
Jan 12, 2009 | Insignia Digital-to-Analog Converter for...
DTV Converter hookup
Is it possible to record TV programming on a VCR when using a DTV converter? h1 = document.getElementById("title").getElementsByTagName("h1")[0];h1.innerHTML = widont(h1.innerHTML); Hi,
I had the same problem and found this answer that worked for me. Hope this does the trick for you.
Simple stated, your VCR must be set to channel 3 also. Check it out.
woody
  1. You must have the VCR tuned to record on channel 3.
  2. You must have the VCR connected to output signal of the DTV converter box. In other words, the converter box must be connected between the antenna and the VCR. So, the likely configuration you would use with a coaxial cable is antenna to DTV converter to VCR to TV.
  3. You must tune the DTV converter to the channel you want to record prior to recording. The VCR won't be able to change channels on the DTV converter.
  4. You will be able to use the timed record function on the VCR but you must adhere to steps 1-3.
If this sounds freakishly familiar to recording on a digital cable or satellite set-top box, you are right. It is exactly like recording a signal from a digital cable box or satellite receiver. While it may be inconvenient to perform the steps above, at least the option still exists to record on a VCR while using a DTV converter box.
Disadvantage of DTV Converter: You will lose the ability to watch one program and record another with the DTV converter. Sorry for the bad news.
The reason is the tuner. The VCR tuner is useless with digital except for recognizing channel 3. The digital converter is a single tuner item so it only receives one station at a time.
Oct 17, 2008 | Emerson EWV603 VHS VCR
Televison & Video Logo
Top Zenith Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
