Step daughter hit a button on the TV remote and it will not let us turn the televion off and on with the remote. We are having to use the button on the front of the tv. We can still adjust the volumn so the remote is not dead just will not turn Tv off and on. What do we do to fix it
My tv is lock how can i unlock. Nikai 2990. All key is lock
JustAnswerhttps://www.justanswer.com > TV Problems
Oct 9, 2017 - Then on the actual TV, hold the power button for 60 seconds then release. Then wait 10 minutes, connect the power again to the TV, turn it on ... 1 answer · Top answer: Get that remote and it will work
Step 1
Turn on the component you wish to sync to your universal
remote--your television, DVD player, VCR or stereo.
Step 2
Point the remote at the device you are programming and press
the corresponding device button on the remote. These buttons are labeled
"TV," "VCR", "DVD," etc. Hold the device button for three to five
seconds.
Step 3
Push the power button on the remote. This should turn on the
device that you are syncing.
Step 4
Push the "Channel Up" or "Channel
Down" button on your remote gradually until the device that you are
programming shuts off.
Step 5
Press "OK" or "Enter" on the remote once the synced device
turns off.
Step 6
Press the device button for the component you just
programmed, and hit the power button while pointing the remote at the
component. If programmed correctly, the device should turn on, and you
should be able to control it with your Living Solutions Universal
Remote.
Step 1 Turn on the component you wish to sync to your universal remote--your television, DVD player, VCR or stereo.
Step 2 Pointthe remote at the device you are programming and press thecorresponding device button on the remote. These buttons are labeled"TV," "VCR", "DVD," etc. Hold the device button for three to five seconds.
Step 3 Push the power button on the remote. This should turn on the device that you are syncing.
Step 4 Push the "Channel Up" or "Channel Down" button on your remote gradually until the device that you are programming shuts off.
Step 5 Press "OK" or "Enter" on the remote once the synced device turns off.
Step 6 Pressthe device button for the component you just programmed, and hit thepower button while pointing the remote at the component. If programmedcorrectly, the device should turn on, and you should be able to controlit with your Living Solutions Universal Remote.
Step 1
Step 2
Point the remote at the device you are programming and press the corresponding device button on the remote. These buttons are labeled "TV," "VCR", "DVD," etc. Hold the device button for three to five seconds.
Step 3
Step 4
Step 5
Step 6
Press the device button for the component you just programmed, and hit the power button while pointing the remote at the component. If programmed correctly, the device should turn on, and you should be able to control it with your Living Solutions Universal Remote.
hello here is how you get your remote to work...make sure tv is on step 1.hold down code search button till you see the red light step2. let go of code search button and hit TV once light should blink step3. press and release the power button while pointong a TV u ((may have to press the power button several times)) once the Tv powers off press the enter button once step4. press tv button and hit power
http://remotefinder.rca.com/default.aspx?site=rca This site will give you the codes; Enter the codes 1> Press Hold Code Search until light stays on 2> press device button ie.TV 3>enter 3 digit code from site 4>Try Power button, if works great if not try another code That's It!
