Question about HP Photosmart C7280 Printer
HP C7280 doesn't print 2-side from my computer
My HP C7280, which automatically prints two-sided, had its configuration changed on my computer. Despite it's saying to print both sides, when I send something to print I get an error message saying "The document has been configured to print using the Automatic Two-Sided Printing Module but the module is not installed in the device.". The printer is working normally from other computers. Could anyone help me on this? Thanks.
Posted by bysimon on
Anonymous
    Sniper:
  • 102 Answers
Have you use duplex unit?
you have to change your driver option both side print
Thanks
Posted on Oct 27, 2009
Anonymous
    Scholar:
  • 81 Answers
Are you working with Vista?
There is a known issue with some of the HP drivers in Vista, you will need to update your Printer driver to solve the issue,
Down load the new drivers and follow the instructions
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3204785&lc=en&cc=us&dlc=en&lang=en&cc=us&submit=Go%20»
HP c7280 Stuck in print que...
Please click here and follow the instructions to clear the print queue manually.
Oct 07, 2009 | HP Photosmart C7280 Printer
HP Laserjet 2015n printer
Sir, the Hp LaserJet 2015n printer CANNOT automatically do duplex printing since the printer does not include mechanism and paper storage areas to cycle the paper through the printer a second time and print on the reverse side. Manual duplex printing can be done as follows: Choose duplex printing and remove all sheets after the printing is complete. Turn the sheets over while preserving the orientation and insert them in the paper feed path. I have an HP 1020 laserjet printer which is similar to the 2015.
Aug 22, 2009 | HP LaserJet P2015n Printer
Prints off the paper
Check the settings on the printer itself. It may be set to legal and this might override the properties settings. It probably is not printing duplex because it is waiting for the other 3 inches of legal.
Aug 03, 2009 | HP Photosmart C7280 Printer
HP P2015 will not print on both sides (automatic mode)
Properties --> Device Settings --> Duplex Unit (for 2-Sided Printing): Not Installed ------ This need change to 'Installed'
Jun 16, 2009 | HP LaserJet 1320 Printer
Cannot get printer (hp C7280) to print double sided
There is a new driver from april 2009 on HPs site which adresses this problem. I installed it, and now everything works fine. You have to download and install it yourself, it doesn´t update automatically.
Apr 26, 2009 | HP Photosmart C7280 Laser Printer
My HP C7280 all-in-one printer is supposed to be able to print on both sides of the page. Also, I have some specific printing rules that I created in the printer set up menu. Every once in awhile, I turn...
Is this on XP?
Read this document from HP:
Does your unit have the optional Duplexer?
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087162&cc=us&lc=en&dlc=en&product=3204785
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Apr 13, 2009 | HP Photosmart C7280 Laser Printer
Not printing in color
the document below tells you how to change the settings to color printing. Please try to follow the SOLUTION under STEP ONE, if that wouldnt solve your problem, go down and follow the rest of the steps.
CLICK HERE TO VIEW DOCUMENT ==> DOCUMENT
Please, let me know the result after following the document.
thank you so much.
adonscott
Aug 04, 2008 | HP Photosmart C7280 Printer
HP photosmart C7280 will not print. it is correctly plugged in and the computer screen is saying ready to rpint, but it will not print at all
Hit * and # at the same time on your printer
Enter code: 123
Hit Right Arrow
Go to System Configuration
Hit OK
OK again
and OK a third time
Unplug power from printer
Unplug power from wall
Wait 2 minutes
Replug the printer
It should boot fine and be able to print again.
May 22, 2008 | HP Office Equipment & Supplies
HP Photosmart C7280 Printer Logo
320 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
