Sony Playstation 3 (PS3) Console Logo
Posted on Oct 27, 2009
I have the ps3.60.After switching on and putting in dvd(blue ray) the tv screen shows ps3 on the right of tv screen then the ribbon across screen but does not progress any further, almost as though frozen at that stage.
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Oct 27, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
26158
Points
17
It may be that your ps3 automaticly loads the disc and has already started to play it and it might be trying to change the resolution(happens to me all the time) try un pluging your lead then plug it back in
hope this helps
I HAVE A BLUE SCREEN. WHEN YOU PUT A DVD IN, DVD SPINS BUT NO PICTURE JUST A BLUE SCREEN.
Hi eme i suggest you change the lense or check your connection it might be you did not plug the cords connecting to tv in order for it to show. From deborah.
When I Insert A Cassette Into My Sansui, It Shows A Blue Screen With Nothing Else Written On The Screen. It Plays The Audio Perfectly Though. I Have Tried Many Head Cleaners But None Seem To Work.
is the yellow jack plugged into video out (DVD) to video in (TV).......is the TV on ch 3? if there is a switch on the back of player is it switched to 3 also?
1helpful
When i try to play a Blue Ray DVD, the LG LCD tv gets a swath of bright green random pixels across the middle of the screen. The player is connected by an HDMI cable. I have replaced the cable twice,...
Pickled! You did right by checking the cables, the tv inputs and as well the output on the blue ray...even by replacing the blue ray. Which leads to a problem within the tv monitor. I can only guess there is something in the software of the tv that is causing the problem. I can only suggest two options. If can connect the tv to a network via CAT5 cable, you can do a frimware update to the tv. Sort of like a software update. If it is not available, try to swap the HDMI cable for the 5 RCA component video. It will still carry HD signal, just not as crisp as the HDMI. I would be floored if the same thing happened with the component cable.
2answers
SONY BLUE RAY ONLY SHOWS IN SMALL SQUARE. THE
Have you gone through your TV's menus? You may have to change screen resolution from within the TV's settings to get a full screen presentation.
2helpful
Magnavox MDV560VR DVD/VCR combi
f you accidentally set Progressive Scan to ON (within
Analog TV), press STOP 9 for five seconds to restore the
picture to normal operation.
DVD/VCR progressive blue screen
perhap there is a menu button on the tv itself,then you need scroll through the menus
1helpful
WT-46809 Inputs show lines across screen
1. THE SYMPTOM IS BRIGHTER IMAGE ON THE SIDES AND DARKER IN THE MIDDLE. THE PROBLEM CAN BE WITH RED BLUE AND/OR GREEN. CHECK FOR PROPER CONNECTIONS TO THE "DAG COATING AND CONNECTIONS TO PIN 9 ON THE SOCKET OF THE AFFECTED CRT. MAKE SURE THESE GROUND POINTS ARE COMMON WITH CHASSIS GROUND.
Small picture screen
on the remote there is a button called "View Mode" on the bottom right that changes the size of the screen. Try that. I don't know you would adjust it without the remote
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
