Chainsaw will not start there is no spark ,how do you access the points and condenser of a model 330 homelite chain saw?
Homelite 330 – no points
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/baf9791bfc773f1a88256c2600142688?OpenDocument
Please try this
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You don’t have to bend up the electrode. HTH
Lou
If I remember correctly, the model 330 homelite has a solid state ignition system. the only way to check it is to disconnect the stop switch wire from the module, make sure the air gap is set at .010 and check the spark with an old plug or an unsuspecting friend. If there is no spark, the module needs to be replaced.
