Yup theres a trick.. the trick is to be able to fit behind the unit once stacked to make final connections then climb out and push the units back into the hole..
the main problem is not kinking or otherwise damaging the vent or the gas line when pushing the thing back, hence the climb over make the connections then climb out attack..
never had any luck trying to connect it up while out in the open then stuff it into the hole..
it can be done, just takes time, and patience..
hope this helps,
best of luck,
ttfn
