The belt doesn't have to be broken to be bad. Even if it is stretched or worn it will not turn the brush roll properly. Here is the belt you need and the manual which has instructions:
I thought my belt went bad....which it did, however there was another issue....The brush was not turning freeley, and would hardley turn at all, which caused my belt to go bad. Apparently, there are sealed bearings in the brush that you can not get to. If your brush will not turn, you can either spend some $$ and get a replacement. I opted to spend some time on mine, and soaked it in some Mr. Clean and water. I then sprayed brake part cleaner into both ends, and re soaked it. I then put some dish soap on either end and freed up the bearings. In between each of the steps I described above, I would try to work it by hand. I have not had a problem since, and saved some $$ too! Good luck and hope you get the same results I did;-)
