I have a Remington 104316-05 pole saw that died today. The motor was loosing speed over time with gradual use. Today it finally quit. What parts do I need? Armature? Field and brush assembly? There is no burning smell coming from the motor and the saw has been well maintained. Any assistance would be appreciated so I can get parts on order as I understand Remington Power has closed up shop. Thanks
Sorry for not getting back to you sooner, didn't see it. I honestly don't know the answer to your question. Do you have a friend or neighbor with one of these? You won't do any lasting damage performing what you discuss. Even if you determine what has failed I seriously dought you will find any parts.
Lou:
I'm well aware that Remington Power has closed up shop. But there are still replacement parts available in the stream. I'd like to repair this thing as it cost me $169 plus taxes a couple of years ago.
Here is my question. What resistance should I be reading across the field terminals with my VOM? 2. What resistance should I see with my VOM across the armature terminals? If I can get an answer to the resistance checks, then I can order either a field and maybe brushes, and or an armature and make it work.
Any info on resistance checks would be appreciated.
All electric parts for your saw are NLA, but you knew that. I suggest you buy a name brand replacement that you can expect to have replacement parts 5 - 10 years from now. Sorry Lou
Guys, it turns out that the fix for my pole saw was very simple. The carbon brushes were worn out. So if anyone has one of these Remington Pole Saws that has lost power and quit, simply remove the armature and replace the carbon brushes. BTW, carbon brushes are readily available on the net. Cheers.
