Hi there!
The HTC Touch Pro does not easily natively sync with a Mac computer. There are a couple of pieces of software you could try to get pictures from your phone to your computer.
One is the Missing Sync for HTC Touch from Mark/Space - http://www.markspace.com/products/htctouch/htc-touch-sync-mac.html
This program has been well tested. I've used a different version (for a palm phone) and it works well. It costs $40.
Another program that I do not have experience with is SyncMate for Mac from Eltima Software - http://www.sync-mac.com/
Unfortunately, only the $40 version syncs photos.
If you have a microSD card in your phone, you can put photos on the card, then use a USB card reader to put the files on your computer.
There is also a possibility of using bluetooth or email to transfer the photos. You can email yourself the photos and pick them up on your computer, or possibly transfer the files with bluetooth.
I have never used the HTC Touch Pro before, but the process to get bluetooth started should be something like this...
- Make sure your smartphone is set to "Discoverable"
- Go to System Preferences > Bluetooth on your computer.
- Click the "+" button at the bottom of the device list.
- Select your phone from the list when it shows up and complete the Bluetooth Setup Assistant.
- On your phone navigate to the photo and try to find an option to send the photo via bluetooth. You will have to accept the transfer on your computer and the file will most likely go to my documents.
I hope this helps!
plug it in to ur orignal computer u put everything on then u plug it in then it comes to ur optins then under the big pic of ur i pod u click restore and i will take off ur pass code and everything elce. then u just sync it again and it will b fixed
Connect your iPod to your computer as you normally would with the USB cable. Step 2 Open iTunes if you don?t have it open on your computer already. You will be able to access photo options from here. Step 3 Choose ?Preferences? from the iTunes menu. This will pop up a tab where you will be able to complete step 4. Step 4 Click on the iPod tab in the screen that will open up after completing step 3. Step 5 Select the ?Photos? tab in the ?iPod? pane you chose in step 4. Step 6 Choose the ?Synchronize Photos From? checkbox and select either "iPhoto," "Choose Folder" or "Pictures" (as in your pictures folder) from the pop-up menu. try this and see if it helps
you need to check the generator in series with flame present. remove one wire from gas valve.put 1 of your meter probes under gas valve terminal where you removed one lead from powerpyle generator.put generator on other probe anything over 600 mv and your generators is ok under replace
The service manual should have a procedure for aligning the gearing,
BUT a lot of times they don't. Almost always, you can figure it
out as they put little tiny arrows or marks molded into the gears
showing which teeth line up. This usually is done in in the eject
position.
If you succeed here, you can regard yourself as "mechanically inclined".
Hope Ya Fix It.
