Question about Garden
No spark ,wont start,its getting gas put in new spark plug Tecumse 6.5hp Family GTPXS,1951BC
Posted by chasnbren on
Roger Geer
  • 78 Answers
First thing to check is the kill switch. This is on the engine brake system. Sometimes they become misadjusted and dont stop making contact. If that system is ok then the ignition module could be shot.
Posted on Oct 27, 2009
  • curiousgoods
    curiousgoods Jun 15, 2014
    Clean the coil,and magnito.Steel brush.
Honda lawn mower wont start
fuel spark air has to get all in the proper time to fire remove plug and squirt a little gas in hole put plug back and try again
Apr 18, 2015 | Honda Garden
Chain saw will not start
sure sounds like you did it all.
Was the Plug wet with gas when you took it out to fuel it directly? I would take the plug back out, blow out or let the Cylinder totally dry. Then spray a bit of Starter fluid in the carb and see if you get life.
Old gas left in a saw is a Carburetor killer. The paper components in these carbs can not stand the new 10% ethanol gas.
Dec 06, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
My daughers 1999 altima ran out of gas, we put gas in it, & it still wont start, we replaced the rotor cap & spark plugs, it getting plenty of fuel but still wont start, what can it be?
Hello you will need to replace the spark plugs you quoted it is getting lots of gas so your spark plugs are wet.disconnect your battery while your replacing your spark plugs once finished replacing the spark plugs reconnect the battery now try to start it should start up.
Jan 10, 2011 | 1999 Nissan Altima
I have a 98 honda foutrax 300 4 wheeler it started acting up and now it wont start took the carb. off and cleaned the jets and everything up and pulled the spark plug out and put my fire over the hole and...
remove all of the old fuel using a siphon bulb and hose. Put in brand new fuel and make sure the line from the tank to the carb. is flowing gas. if not clean or replace the fuel line
Jun 17, 2009 | Honda NS 250 R Motorcycles
I have a toro-recycler. it is about four years old and has always run great-until now..it shut off in the middle of the yard and wont re-start. i put in fresh gas/sea-foam, new plug, and air cleaner..it is...
It sounds as if the gas cap may be clogged. It must be able to breathe so that the carburetor gets the proper gas flow. Does it run for about 10-15 minutes? If so, this is more than likely your problem.
Jim
Jun 08, 2009 | Toro Lawn Mower With Toro Power Tools
Wont start with new plug. I can smell gas, but none on plug
Check the start stop switch, sometimes they can get dirty causing the saw not to get spark. Also maybe check Your air cleaner. if it's clogged it may be flooding itself out?
Jan 26, 2009 | Makita DCS6401 20 20",64cc Chainsaw 2...
Wont start
Hi
Check the spark at the plug,the compression and carburation.Check and clean the gas and air filters.Disassembly thr carb and clean it with compressed air.Change the gas from gas tank and start the engine.
best regards savumihai71
Dec 20, 2008 | Coleman Powermate Powermate 5000W...
Wont start
Start with emptying the gas tank totally. Refill with fresh gas/oil mix. Todays gasoline ain't that great.
Also after putting in fresh gas and priming if it doesn't fire at all pull the spark plug and if it is dry, pour a about a tbsp. of mix gas in the plug hole. put the spark plug back in and see if it will fire.
Phil
Dec 07, 2008 | Garden
Garden Logo
123 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
