Question about Refrigerators
Wine cooler Doesn't work
I have this cooler no clue which brand it is, but doesn't work
I opened and can see a electronic circuit, I checked out I Founded that
was some components damaged.
One Diode 1N 4007 burned out, a condenser 120uf / 200v pop up, the fuse gone
and two transistor that I want to figured out what kind it is.
They wrote as ( E 616 13005-2 )
Circuit made by: hanny.com.cn
# board: 0757-83835018
Any one with solution any Idea, Thank
Posted by Mark on
  • Mark Oct 27, 2009
    none
  • Chakis Nov 19, 2009
    have the same problem. found something? You know what value are the regulators? My messenger is [email protected]
Anonymous
    New Friend:
I had the same issue on a Whynter WC28S SNO 28 Bottle Wine Cooler, it even seems like most of the thermoelectric wine coolers, fridges, and such have the same boards by hanny. For cross refference parts I used NTE because Fry's Electronics had them.
Switching transistors - NTE51
1N 4007 - NTE125
Silicon Dual Power Rectifier - NTE6090
Also I have a venotemp wine cooler that has pretty much the same board, with the same plugs for fans, light, control panal, and cooler fan for $45 shipped at their site under replacement parts. Hope this helps people looking for info on this. Also research Switching Power Supply issues for information.
Posted on Sep 17, 2010
  • 1 more comment
  • Anonymous Sep 17, 2010
    Got the cooler working today, there was a blown resistor 2ohm (R38 on my board) and also two General Purpose Silicon Rectifiers (D14
  • micdegr Jan 14, 2011
    I have an 8 bottle wine cooler with the same problem; 2 transistors are fried. Of the transistors that you mentioned, which one is the replacement for the fried E 616 13005-2? Thks
    Michel
  • facebook519
    facebook519 Feb 04, 2013
    Thanks for the part numbers! 2 x NTE51, new fuse, plus new 2 ohm resistor got mine up and running again.
Anonymous
    New Friend:
I have the exact problem. same board numbers and parts numbers. mine is a Haier hvw12abb 12 bottle cooler. looking for the same E 616 13005-2
Posted on Feb 26, 2010
Yossef1
I had the same problem.
I had to replace:
two 2 ohm resistors
Two 13005 transistors
3 1N4007 diodes
A 120microF capacitor
and a fuse
Posted on May 21, 2012
  • Dena Yarbrough Jul 03, 2014
    Yossef - might I ask what indications you had that led you to determine the cause of the problem? Were you getting both the red and green leds, etc..? I'm getting the red led to work - so, I know input power to the card is good; however, I don't get the green led and some segments in my digital display are funky.. much thanks. r/
Schramli
    New Friend:
I had the same issue with a bottle cooler, the power supply did not work at all. I found out that the transistor E 616 13005-2 is in fact a MJE13005 which is a common NPN power transistor, very easy to find (farnell.com).
Posted on Jul 07, 2011
Anonymous
    New Friend:
  • Lucas Myer Feb 28, 2014
    can you adjust the temp range on the hanny boards? have a duel both same board but it has two different pre set ranges. Just wondering if i could alter thoes Thanks
Nobody
    Habit-Forming:
    New Friend:
  • 23 Answers
Everyone with problems related to these vinotemp fridges should reference the following forum thread on AllAboutCircuits which has been investigated quite well:
http://forum.allaboutcircuits.com/threads/repair-thermoelectric-cooler.101748/page-3
Posted on Nov 29, 2016
Jon Jellison
    New Friend:
I had same problem. The C-13 capacitor took out the C1 capacitor. Anyone know the value or part number of the C1 cap?
Posted on Jun 25, 2015
24inch Bush smart TV/DVD not working.
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 09, 2017 | Bush Televison & Video
Sanyo CLT2054..........doesn`t have power.....help
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
Jan 02, 2016 | Sanyo Televison & Video
Ultracool Portable Evaporative Cooler CP35--says "no water" but water has been added---how to get it to work.
I have/had the same problem with mine and I know it to be the float as I took it apart and I can get it to work if I remove the circuit, but then if it runs dry and I am not around, I run the risk of burning out the bump. I can't find the replacement part; anyone have a clue where to get parts?
May 29, 2014 | Champion International Champion Cooler...
Lg nsa30lacg
Compressor Starter switch mine was 6R8MG $20,55 at Repairclinic.com
Mar 01, 2013 | Magic Chef MCWC45A Wine Cooler
Doesn't cool
You have troubleshot this thing well. You may have a capacitor problem or starter problem. It will not be design let the unit come on. This is all to protect the expensive compressor.
Feb 03, 2013 | Franklin FWC100 Wine Cooler
Wine cooler doesn't cool
I recommend that you maybe add more details to your question so it will be easier for Experts to understand the question and answer it.
Oct 06, 2012 | Kalorik WCL-20629 18 Bottle Dual Zone Wine...
What is the best wine cooler in the market?
The NewAir AW-210ED is by far the most successful wine cooler there is making the best wine cooler overall for the price. The only downfall is that this specific model doesn't have the highest capacity for the price.
Aug 14, 2012 | Furniture
Where is thermostat?
You can find manuals out there on the web. When I look for the part the only thing that made sense was the control board in the lower rear of these coolers, and doesn't seam to be adjustable. Then there are the buttons on the top front, but not sure if the stat is serviceable by itself.
Jul 08, 2012 | Haier BC112G Wine Cooler
What is the best temperature for white wine to be in?
It is important to keep the wine cool and in stable temperature that doesn't fluctuate very often. Bright tart white wine: 48-52 degrees; sparkling wine: 50-55 degrees and rich white wines: 58-62 degrees.
May 29, 2012 | Furniture
Refrigerators Logo
11,193 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
john h
