Question about Avanti Art Deco 4-Cup Espresso Machine
I recently bought an Avanti Art Deco 10 cup espresso machine and am disappointed that I cannot make HOT coffee with it. What can you suggest?
Posted by nml7 on
Anonymous
    New Friend:
When the water boils in the bottom chamber the steam creates pressure and pushes the water through the grounds and into the top chamber. It's hard to imagine that the water going through the grounds is not close to boiling temperature unless you are using the coffee maker at high altitude where the temperature of boiling water would be lower.
Posted on Feb 28, 2010
Will not percolate. Water is poured, it heats up, no coffee brew
Bunn Home brewers don't perculate. They work the same way that commercial brewers do. Fillit with water, let it heat for about 20 minutes, then put your filter and coffee grounds in the funnel, pour a pot of water into the machine, put the pot on the warmer, and let the water run through. Then enjoy a nice hot cup of coffee.
Apr 12, 2010 | Bunn BX HOME BREWER 10-Cup Coffee Maker
Water not going into cup
hello can't seen to get the water to come out in the cup
Nov 23, 2009 | Braun Tassimo Espresso Machine/Coffee...
I put in 12 cups of water and only 4 cups come out with coffee what is wrong with this. It is only one month old
This occurs occasionally if the unit needs cleaning or you are brewing a new pot of coffee immediately after emptying a hot pot of coffee.
Run a cup of vinegar through the coffee maker twice, run at least 2 pots of clean water through to rinse the vinegar out.
This should clear the problem until it needs cleaning. The suggested frequency of cleaning is every 30 pots, but this varies depending upon the type of water you use.
Nov 16, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Avanti stovetop exploded while on the stove
Could this happen if you fill the bottom chamber over the pressure release valve so that the steam pressure built up and couldn't be released. Or perhaps the pressure release valve got blocked. Not sure. But it is important to take it off the stove promptly when you hear it make that gurgled hissing sound that indicates the top chamber is full and now steam is coming through rather than water.
Jan 10, 2009 | Avanti Art Deco 4-Cup Espresso Machine
Gaggia cubika, weak coffee.
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Nov 08, 2008 | Gevalia 35411 / 50433 Coffee Maker
Saeco magic
I believe the model you have has no user-selectable temperature settings. The manual for the Magic line suggests preheating the cups as the fix. You can use the electronic cup warner OR run your tap/faucet water as hot as possible, fill the cup you're going to be dispensing espresso into with hot water while your Saeco warms up...right before you hit the button to dispense espresso, empty the hot water, dry the preheated cup and you're set! It only takes a few seconds. This way, you waste none of your coffee's thermal emergy on cup heating and your coffee will stay hot longer. Hope this helps!
Jan 02, 2008 | Saeco Magic De Luxe Espresso Machine
Avanti Art Deco 4-Cup Espresso Machine Logo
559 people viewed this question
Top Avanti Coffee Makers & Espresso Machines Experts
ThaMp3Doctor
ThaMp3Doctor
Marvin
Marvin
Ross Keen
Are you an Avanti Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
