Question about LG L1920P 19" LCD Monitor
LG Flatiron monitors.1st one on Dell pc works great. 2nd one in same household to Compaq pc still flashes faint pink on parts that should be white.
Posted by valoriewells on
  • Louis Ebert May 11, 2010
    Hi there valoriewells, The very first thing to inspect would be the monitor cable connector that connects to the Compaq vga connector on the pc. Look closely to verify that NO GOLD FLASH PINS are bent, broken, or have been pushed down into theconnector plastic body. All pins should be of the same height!! If problem persists try connecting it to a fully booted KNOWN GOOD pc with the WIN-desktop showing. then and only then power-up the "faint pink" monitor to see if the problem has followed you to the Known good pc! OR try just the reverse test. Let me know the results by doing a comment to your above post. good luck. I'm 12fix louie
Anonymous
    New Friend:
  • 9 Answers
Probably just some color balance is of. Reset white to something different on the compaq. Try downloading nvidia-settings and see what happens when you mess with color balances. Mess around with some settings til it looks right, or see if you can reset the white balance to a different preset on the monitor's menu
Posted on Oct 26, 2009
My LG flatiron W1943TB turns on, says analog power saving mode, goes black and then the power button flashes.. but the monitor is hooked up to my dell notebook bc my LCD died
Hi erin mckinle,
That is probably it's, uh, analog power saving mode. When the screen goes black and the power button flashes, make some mouse gestures or hit some keys that would not affect anything (try spacebar). That should bring up the screen. If you think it goes into power saving mode too fast, go to Control Panel --> Power Options, and change the values. Hope this helps.
Jan 02, 2010 | LG W1934S-BN 19" Monitor
Tower powers up great,but monitor has no signal
1st if the monitor light is yello and as soon as u switch on the comp,or if the monitor goes to sleep even though u ave checked the connection wht u need to do is u need to reset the graphic card if u ave a add on card and then clean the slot check for any damage or moisture and then put it back and reboot.i m working for hp ave got lots of those cases
'2nd wht u can do is press space bar and slightly tap the power button of comp seeif tht helps.let me know wht happened and in detail
Aug 25, 2009 | Compaq Presario 5000 PC Desktop
I have a compaq desktop, winxp sp3. white has turned pink
The monitor needs some minor repair and alignment that's all
If you are any good with electronics and have a bit of decent test gear lying around you could probably do this job yourself.
But if not then a local TV or computer repair shop will be able to handle it and it should not cost too much.
Its a common problem on older CRT type screens
Aug 19, 2009 | Computers & Internet
Monitor colors are not displaying correctly
Hi, At the worst it is a blown monitor, but have hope. 1st try a new or known good lead, between monitor and PC. 2nd put monitor with own lead on good PC. if 1st works = result. if 2nd and monitor is same, suspect monitor, however, if 2nd works ok on other PC, then look at ur vid card. Either way, this test sequence should save you some $. Be lucky.
Aug 15, 2009 | Acer AL1916W 19" LCD Monitor
Added as 2nd monitor, color PINK
Check the cable...are any of the pins damaged, bent or missing? Can you access the Monitors control panel and reset its settings to factory default?
May 17, 2009 | Samsung SyncMaster 920NW Monitor
White turns to pink on acer laptop
The problem is CCFL light bulb in the screen. It is starting to die :( Can be replaced but that is not an easy task (easier is to replace screen as new bulb comes with it)
Jan 12, 2009 | Acer Aspire 5630 Notebook
Monitor automatically clicks into power saving mode
check the primary settings for your default video card.
Jun 08, 2008 | Dell Dimension 4600 PC Desktop
Pink-hued display
one try a degauss
second check the cable wich connect the monitor to the pc video card.
third. keep away the magnetic things like speackers from the monitor..
bye:)
Feb 03, 2008 | Compaq CV 7500 17" CRT Monitor
LG L1920P 19" LCD Monitor Logo
186 people viewed this question
Top LG Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
