Cause
Defective harness between drum motor and engine PWB (YC11), or
improper connector insertion.
solution
Reinsert the connector. Also check for continuity within the connector harness. If none,remedy or replace the harness.
cause
Defective drum motor drive transmission system.
solution
Check if the gears rotate smoothly. If not,grease the bushings and gears. Check for broken gears and replace if any.
cause
Defective drum motor.
solution
Replace the drum motor.
cause
Defective engine
PWB.
solution
Replace the engine PWB
