Televison & Video Logo
Posted on Oct 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It made popping sound and went dark, no picture. You still can hear the audio on a channel. Fan was making louder noices for a while and the top right corner of the screen have been getting dark before it finally went dark.
Anonymous
Level 3:
  • Master 668 Answers
  • Posted on Oct 27, 2009
Anonymous
Master
Level 3:
Answers
668
Questions
Helped
190501
Points
1925
I believe the Lamp has failed.
I hope this helps,
Skyassoc
I have around a 2000 artic cat 4x4 and its making a loud poping noice by the clutch are what could it be?
Sounds like toward shift linkage isn't fully engaging. Check and adjust cable and linkage.
Aug 11, 2017 • ATVs
Background noice on tv is too load, can't hear voice.
Look carefully in Menu---many Toshiba sets have a HALL or Theater setting which will make background louder than people talking--likely your problem and the owner manual should explain this.
I have an 883R converted to a 1200 w/Andrews Cams and a Mukini Carb. Since the conversion the top end leaked oil which a friend changed the gaskets on. However, since he changed the gaskets, the...
I'm going to guess at this one since I can't hear it. I'm going to guess a blown head gasket. People describe the noise in different ways. Some say it sounds like a squeak and I think it sounds like a whistle. Let the bike sit overnight and get stone cold. Before you try to start the bike, pull the spark plug wires off the plugs but leave the plugs in the heads. Open the throttle wide open but leave the enricher off. Turn on the ignition and press the starter button. Is the noise louder when you do this or is it louder when the engine is warm. If it's a head gasket, it should be louder when the engine is cold.
The only thing on the upper left side of the engine is the rocker arms and valve springs. There is a possibility that your friend got the center portion of the rocker box cover just a bit too close to one of the valve springs and it's hitting the center cover. Take a screwdriver and use it like a stethoscope and see if you can locate the noise. Feel the "alignment" of the lower, center, and upper rocker box covers. If the center and top cover are not in their proper position, this could be the problem.
Good Luck
Steve
2helpful
42edt41a hitachi plasma tv went dark sound ok
sounds like your y and z drive boards over heated and need replacing...
Tv popped and picture went out
im srry to tell you that you picture tube blew in you tv this can happen from many things as simple as a defective one .. to a bad power surge in your house ... if it is under warranty they will fix free of charge .. if not you'll have to get a new tv .. a new tv in most cases is cheaper then tryin to just by the tube .. oh and if its not under warranty .. you could always just say it surged and claim it on you home owners insurance =]
1helpful
2answers
42 inch LG Plasma TV - Lost picture
Most likely what happened is one of the capacitors went bad. When a capacitors goes bad it produces a popping sound. This could be an easy and cheap fix if you find the bad capacitor or capacitors. The bad capacitor will have a bulging top most likely on the power board but could be anywhere.
2helpful
Hi , I recently had the same problem which I was determined to fix . So I did a few weeks of research to find that it was the Y SUS board which burns out. I'm sure you realized that the TV gets hot. Personally I think this is why. circuit boards don't like heat and I've learned that the cooling fans are a joke. I replaced the board and got my picture back. I proved the fan theory because after the screen started to act up. I placed a cooling fan near the vent holes on top and the problem cleared right up,It also helps if you lower the brightness which helps out on the heat situation.I will soon be adding a fan with a temp. sensor. This shoud help if your screen has lines when you initially turn the cool TV on.then I have Some other costless solutions. Hope this helped these are great TV's and like our cars we maintain them not throw them away..................................Mr Wiseman
I do not hear any music through my 10" M Audio Subs (M Audio Sound System)
If you know how to use a multimeter, you can test the amp this way:
-unhook the subs
-hook up a cheapie speaker you know for sure works to one of the channels
-unhook the audio inputs
-turn the amp on
-set your meter to VDC
-put the positive probe on the inside of the input connector, being sure you make contact with th inner contact
-take the negative probe and tap it on the outside of the connector
What you are doing is sending a low voltage (replicating an audio signal) into the amp audio circuit and allowing the amp to amplify it. If the amp makes the speaker pop each time you strike the probe, the amp is working.
You mentioned you need a 4 channel amplifier make the two, dual voice coil subs operate. The is not true and by hooking them up like that, there's a chance of damaging the subs. The reason is that the dual voice coils are interwoven and they have to get electrically identical signals or they fight against each other. The can mechanically fail, then, electrically fail, then even damage the amp too.
My picture went dark but the audio is ok on Philips model 51pw9303
your tv needs to be taken to tech i is having problem in the video and related circuit.or power supply.good luck
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
