I can't locate my user manual for my MER6769 Gemini Double Oven. How do I set my oven (temp & time) to come on at a certain time & to stop at a certain time? Thanks
Question edited for clarity and toss in a load of CAPS.
Disconnect the element and the fan and check them both for continuity with a multimeter. If the circular element or the fan fails, nothing works, so it could be either.
I am attaching a Gemini manual. The checking procedures are the same for your oven. Two component suspects for your problem would be the door latch mechanisms and the oven temperature sensors.
F9 code usually means that the temp sensor in your oven is at fault . The electronic oven control is sensing a fault with that part. that part is pretty simple to replace Call a local service company with model and serial # they should be able to get the part for you ! Temp sensors are usualy located inside the oven in the upper left hand corner 2 screws hold it in place .It pulls out and has a conector on the back that unplugs.
