Question about Canon imageRUNNER 5570 Copier
Finisher cant be used - Canon imageRUNNER 5570 Copier
Posted by coates617 on
Anonymous
  • 168 Answers
Ok touch the add functions key then common settings scroll down till you see limited functions turn that to off then power down machine with switch on right side turn back on . Make sure nothing is in the wayof the sorter bins. if it still throws a error you have a problem with your sorter
Posted on Oct 26, 2009
I cant save the time. when im finished adjusting the time i cant save it. it still blinking. what can i do??
Push the clock button after again after you have finished adjusting the time
Apr 02, 2017 | The Watches
Cant process update status code 3080-351F-1380-2203-C000-0001
Is your xbox modded? if it is then you must update your customer firmware then finish the update loop.
If its not then go to xbox.com/support and download the latest update files and use a USB to finish the update
Thanks
www.1RepairStop.com
Sep 10, 2011 | Microsoft Xbox 360 Console
Tacky, sticky finish-how do I correct that ???
if its a cheepy from e-bay you cant,,,its all down to the kind of paint used,,it just hasent dryed yet
Jun 29, 2010 | Bushnell Trophy Multi-Reticle Red Dot...
Bought used washer porcelain tub finish is worn off in bottom
get rid of the machine
cant imagine a machine that old really cost that much.
pocelain is baked on and is glass so any edges will catch and destroy cloths
Oct 08, 2009 | Washing Machines
Need a main drive belt for 60'' finish,how long is it? Swisher finish pull behind
they make a ajustable v-belt for problems like this.look on internet for ajustable v-belting. i forgot what it call we used it in a sawmill
if cant find get in toutch with me and ill find it for you
Jul 21, 2009 | Swisher 60" 13 Hp Trailmower #T1360h
Colour cartirage finishes without using
Click the "Advanced" tab while in the "Printing Preferences" window. Choose the "Print in Grayscale" option to print in only black and gray to save on your color ink.
Jun 19, 2009 | Brother DCP-130C InkJet Printer
Finisher door closure switch/sensor not working.
Have you tried to turn the copier OFF and unplug the finisher and turn the copier back ON with out the finisher pluged IN. If it works just don't use the finisher. I believe that model is rather old and you may have a problem finding parts for it, there are a lot of different reasons for the door not being showed closed. Good Luck
Apr 05, 2009 | Office Equipment & Supplies
Finished an os installation but cant get the sond
Is that A30 or A300? and for XP or Vista?
Mar 06, 2009 | Computers & Internet
Canon imageRUNNER 5570 Copier Logo
118 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Ekse
