Leadtek WinFast K7NCR18D Motherboard Logo
Posted on Oct 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ref:Winfast K7NCR18D DC- NFORCE2+ motherboard with Athlon 2800XP and DDR 400 memory. System has been working, but computer says processor is 1.25GHz (I thought it was faster eg 2.08GHz), so I tried using BIOS ''Advanced Chipset Features'', changing FSB freq from 133 MHz to 200MHz. Saved this and exited and now nothing works. Unfortunately I do not have a system boot up disk! What can I do?
  • daviddriscol Oct 26, 2009
    At start up all I have is a blank screen, so I have no control
Burim Hoxha
Level 3:
  • Master 468 Answers
  • Posted on Oct 26, 2009
Burim Hoxha
Master
Level 3:
Answers
468
Questions
0
Helped
131272
Points
1343
Reset settings from bios to default.
1helpful
CAN U PUT 2 GIG OF RAM INTO THIS MOTHERBOARD
Yes you can.
Your main board has the following type of ram:
2 x DDR SDRAM PC3200, 2GB max 400/333/266MHz
Part Number EP-8RGMI Manufacturer Epox Price Check Find Best Price Downloads BIOS
Drivers
Manuals Chipset Nvidia nForce2 IGP+MCP North Bridge Nvidia nForce2 IGP (IGP128 v2.0/400) Socket Socket A (462) Processor Types Athlon, Duron Number of CPUs 1 Front Side Bus 400/333/266MHz Memory Type DDR Memory Channels Dual Maximum Memory 2GB External Graphics AGP8X IGP Nvidia GeForce4 MX South Bridge Nvidia MCP Audio 6-channel IDE 133/100/66/33 SCSI None SATA None RAID None LAN 10/100 Firewire None USB USB 1.1 Expansion Slots
  • 1 x AGP
  • 2 x PCI
Drivers
  • 1 x AGP
  • 2 x PCI
2answers
Dont know the ram that it use. wat is the number on the battery
  • K8M800-M7A
  • Support DDR 333/400 MHz
  • 2 x DDR DIMM Memory Slot
  • Max. Supports up to 2GB Memory
  • the battery i dont no
  • hope it helps
  • Biostar K8M800-M7A - motherboard - micro ATX - Socket 754 - K8M800 specifications
    • General
    • Product Type Motherboard - Micro ATX
    • Cache Memory None
    • Chipset Type VIA K8M800 / VIA VT8237R
    • Max Bus Speed 800.0 MHz
    • Processor Socket Socket 754
    • Max Processors Qty 1.0
    • Compatible Processors Athlon 64 , Sempron
    • Memory
    • Max Supported Memory 2.0 GB
    • Supported RAM Technology DDR SDRAM
    • Supported RAM Speed 400 MHz , 333 MHz , 266 MHz
    • Graphics
    • Graphics Controller VIA UniChrome Pro
    • Memory Allocation Technology Shared video memory (UMA)
  • 1helpful
    Mother board manual for Acer T180 PC
    WinFast K7NCR18 series is a compelling Desktop solution as a Socket A/AMD Athlon, Athlon XP, Athlon, and Duron-based ATX motherboard. WinFast K7NCR18 series, integrating NVIDIA chipset, supports the AMD Athlon processor whose performance is bound to exceed expectation of both consumer and corporate users alike. The WinFast K7NCR18 series also supports a 200/266/333 MHz system bus, PC1600/PC2100/PC2700/PC3200 DDR memories, and the latest graphics devices through the AGP 3.0 8X interface; and allows a direct connection to the graphics and memory for faster access to peripherals. An DVI/TV interface is multiplexed with the AGP bus and can be used to drive DVI compatible flat panel displays, projectors, and digital CRTs and TV monitors.
    The Dolby Digital Interactive Content encoder is also integrated that can also process and output a Dolby Digital audio stream directly to a home theater system via a S/P DIF interface. WinFast K7NCR18 series offers innovative design, support for high-volume DDR memory, and configuration options that optimize performance and provide a robust, mainstream platform...
    or visit at (www.ebookmanual.net/k7ncr18-series-socket-a-motherboards-user’s-manual.html)
    Please post your feedback and Vote if the problem resolved as per your satisfaction.
    1helpful
    Hi, Am after Chipset nVIDIA nForce2 400 + MCP Processor AMD Socket 462 on board. Front Side Bus 400/333/266MHz Front Side Bus. Memory 2 x 184-pin DDR DIMM Sockets. any idea's please
    Only on second-hand sites like ebay. Example of a similar but better one
    http://cgi.ebay.com/Abit-AN7-Nvidia-NForce-2-400-Ultra-AMD-Athlon-XP-2500-/330435195881?cmd=ViewItem&pt=Motherboards&hash=item4cef78f3e9
    1helpful
    2answers
    My motherboard has fried: Albatron KM18G Pro 2003. It no longer seems to be available. For the computer to be exactly as it was before disaster struck, do I need exactly the same motherboard?
    Well you do not need exactly the same motherboard. You need a motherboard that has the exact CPU socket, DDR slots and AGP or PCI slot.
    Here are the specifications for the motherboard: Processor
    - AMD Athlon/Athlon XP/AthlonXP Barton/Duron Processor
    - FSB 200/266/333MHz
    Chipset
    - North Bridge: NVIDIA nForce2 IGP
    - South Bridge: NVIDIA nForce2 MCP
    - I / O Chip : Winbond W83627HF
    Memory
    - 3 DDR Sockets:
    DDR200 to 400 non-ECC DDR SDRAM up to 3GB (Single Channel) or up to 2GB (Dual Channel)
    Expansion Slots
    - 1 x AGP 8X/4X slot (1.5V Only)
    - 3 x PCI slots (PCI 2.2 compliant)
    IDE Connectors 2 ATA133 channels (up to 4 ATA 133 IDE Devices)
    Onboard I/O Connectors
    - 1x Floppy Connector
    - 2x USB 2.0/1.1 header (4 ports USB cable optional)
    - 1x CD_IN header
    - 1x COM Port header
    - 1x S/PDIF in/out header (S/PDIF in/out cable optional)
    - 1x CPU fan header with fan rotation detection function
    - 1x System fan headers with fan rotation detection function
    - 2x 5 pin system panel header (Intel spec)
    - 1x 3 pin Power LED header
    - 1x 4 pin Speaker header
    - 1x Front audio header (Intel spec)
    - 1x Case Open detection header
    - 1x Wake on LAN
    - 1x 4 pin TV-Out header
    So you have to buy a motherboard that has Socket A, that support DDR I memories and has an AGP slot (for the video card).
    If you need further assistance, just leave a comment. Thank you for using FixYa.
    Chip up grade options!
    That
    is a socket 754 motherboard. It will support AMD Athlon processors up to Athlon64 3400+. It is a bit long in the tooth by today's standards, and only uses DDR memory, not DDR2. You may get more of a bang for your buck by buying a "barebones" system, which can consist of a motherboard with processor and memory, depending on how much you want in the barebones package.
    Typically you use the case, power supply you already have with the new motherboard and processor and ram (memory).
    At any rate, if you only want to upgrade your processor, keep in mind that your board only supports up to the Athlon64 3400+. It will support up to DDR 400 ram. You would probably benefit more by buying 2 sticks of 400 DDR ram at 2 gigs each, if you don't have much ram now. If your processor is close to the 3400+, then another processor in that board isn't going to change things much.
    Good luck, and write back if you'd like more help.
    Sirwriter
    Socket754 Supports AMD Athlon64 upto 3400+;
    27helpful
    2answers
    Winfast n15235 motherboard manual
    Mother Board ECS or MSI,Processor AMDuron 2.8 Dual Core w/1333 FSB,1 to 2Gig DDR2 PC667,160 to 250Gig Hard Drive Seagate Barracuda(7,200rpm) or Western Digital,CD/DVDwrite,512Video Card inno3D/Nvidia or ATI Radeon,LG or Samsung,Tower Casing w/ ATX Power Supply 500 to 600watts and LCD/Flat Screen 19inches wide screen or it up to you what you size LCD..Thanks..^_^
    2answers
    Conflict adding RAM memory
    you can deselect from BIOS - CAS LATENCY TIMER to value 2, or better (2,5)
    Processor
    This are the compatible with this motherboard : Compatible Processors - Athlon, Duron, Athlon XP , Processor Socket - Socket A , Chipset Type - NVidia nForce2 400 , Max Bus Speed - 400 MHz .
    This is the complete specs for this motherboard , check this link http://www.shopping.com/xPF-Asustek-A7N8X-X-Socket-A-LAN-nVIDIA-Audio
    Don't forget to rate the solution FIXYA thank you.......
    Top Leadtek Computers & Internet Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a Leadtek Computer and Internet Expert? Answer questions, earn points and help others
