Check if the volume of water supplied to the washer from the water line through the hoses attached to it is good. If yes, the screen inside the water-inlet valve if it is clean. If clean, the water inlet valve is defective and you need to replace it. The water inlet valve is located inside the washer on the upper back portion. It is where the water supply hoses are attached to.
Do you mean you cleaned the hose screens? don't, just replace them,and while the old ones are out run hot water thru hoses you'll be suprised all the scum thats in the hose then replace with new screens availible from ace hardware 3 for $3.50
