Lost electrical while driving. Nothing works. Tried waiting 30 minutes, jump, and charging, still nothing
OK this is the part where You take out your test light or multimeter (best) and start chasing down the disconnect. begin at the battery and then go right to the starter to begin with, then the accessory side of the ignition switch. Once you covered these items continue from battery again and go item by item till you find the problem. Don't forget you need a good ground, regardless so make sure that is good as well. Only do testing after verifying that your battery is fully charged and can withstand a load test, otherwise all testing is invalid. After finding the problem, check the charging system to make sure it's working.
